Go Back   Home > Forums > General Interest > Car Audio
Old 2nd January 2012, 03:39 AM   #1
Default Alpine MRV-F353 Problem
Ok all 5 channels work, but the sub channel has weak audio and measures 27.76 Volts DC on sub out terminals , all fets and drivers check to be ok in circuit
Old 2nd January 2012, 08:29 AM   #2
Post a photo of the inside of the amp.
Old 2nd January 2012, 02:01 PM   #3
Old 2nd January 2012, 09:28 PM   #4
You stated that it has 27v DC and produces audio. Do you have a capacitor in series between the speaker and the amp or did it push the cone fully in/out when you connected the speaker?
Old 3rd January 2012, 01:23 AM   #5
pushes the cone fully out with no signal
Old 3rd January 2012, 01:28 AM   #6
When you checked the smaller transistors, did you just check to see if there were any reading 0 ohms?
You may have one leaking. Check them carefully. If one reads lower than you think it should, pull it out of the circuit and re-check it.
Old 6th January 2012, 10:27 PM   #7
Is the D718 transistor N-channel or P channel? and same question for B688 transistor those are the output mosfets
Old 6th January 2012, 11:13 PM   #8
Neither is N or P-channel. These aren't FETs. The D718 is an NPN. The B688 is a PNP. They are both BJTs (Bipolar Junction Transistors -- or simply bipolar transistors).
Old 8th January 2012, 10:39 PM   #9
both small transistors between output transistors...seem to check good checked several times and saw no leakage
Old 8th January 2012, 11:30 PM   #10
Those are the bias transistors. They rarely fail. The readings look OK.
Alpine MRV-1507 canadianeh Car Audio 9 6th April 2011 01:16 AM
alpine mrv f353 5 channel amp joesch1999 Car Audio 0 6th January 2011 02:06 PM
Alpine MRV-F401 or MRV-F400 Service Manual M.André Car Audio 6 21st February 2010 09:37 PM
Alpine mrv-1000 problem. itte Car Audio 4 15th September 2009 01:37 PM
Alpine MRV-F345 problem shagone Car Audio 1 27th December 2007 07:38 AM
Page generated in 0.35644 seconds (19.54% PHP - 80.46% MySQL) with 10 queries
