Soundstream XTA 880.2 - Page 4 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 6th January 2012, 05:22 PM   #31
Did you check the drive signals with the 1k resistors connected as before?
Old 6th January 2012, 05:31 PM   #32
I think i found the problem.. Solder bridge between the legs of 1 driver..
Im gonna replace the gate resistors anyway since they look burnt but measure fine just so it doesnt look like a cheap repair job...
The 22 ohm resistors i put in that i wasent sure of the value 1 supply it worked fine the other supply it got red hot should i try using a 2 watt resistor to see if it works?
Old 6th January 2012, 07:39 PM   #33
Are you sure that it's a gate resistor and not a pulldown resistor?
A lot of amps use 220 ohm pulldown resistors and they're often 1/2w resistors. 22 ohms for the gate resistors shouldn't be causing any problems.
Old 7th January 2012, 12:05 AM   #34
The 22 ohm resistors just keep burning up..
the resistor in question 1 side connects to the middle leg of the IRFZ44the other side connects to a winding on the transformer..
There are 220 ohm resistors next to the gate resistors what connect to the 3rd leg of the fet..
So any ideas what i could try since the 22 ohm resistors that connect to the middle leg keep burning up and the fets keep heating up in both supplys?
Old 8th January 2012, 12:07 AM   #35
Is the capacitor connected to the 22 ohm resistor shorted?
Did you check the drive circuit with the 1k resistors before installing the FETs?
Old 8th January 2012, 01:29 AM   #36
Back to having problems with the Drive circuit..
I installed 4 1K resistors again 1 in each bank..
Scope is set to .2us 2 volts div
First pic is the waveform on the gate pad for both supplys..
2ND pic is the waveform on pin 9 of the 494
Old 8th January 2012, 03:15 PM   #37
If that's 0.2us, the oscillator frequency is too high. Check the resistor and capacitor on pins 5 and 6 of the 494.
Eton 5-880/25 GOWA Swap Meet 8 23rd June 2011 05:12 PM
Ecler PAM 550,880 lukyrys Solid State 0 6th March 2011 03:50 PM
resistor 880 ohms cathode miguelnoda Tubes / Valves 4 24th October 2010 02:11 AM
Eton 5-880 jmillerdoc Multi-Way 2 25th July 2009 10:17 PM
again on Philips CD 880 jazzigor Digital Source 2 5th January 2007 04:09 PM
Copyright 1999-2017 diyAudio
