THIS AMP DOES SOME WIERD STUFF..
THE AMP WILL POWER UP FOR ABOUT 5 SECS THEN THE POWER LIGHT STARTS BLINKING VERY FAST AFTER ABOUT 30 SECS THE POWER LIGHT WILL REMAIN SOLID AND THE AMP WILL POWER UP FO 5 SECS THE THE CYCLE REPEATS.. I REMOVED ALL OF THE OUTPUTS TO TEST THEM WHILE OUT OF THE AMP I TRYED POWERING IT BACK UP AGAIN AND IT DOES THE SAME THING.. WHILE THE AMP CYCLES I TRYED TESTING THE 494 AND ALL OF THE VOLTAGES ON ALL 16 PINS PULSE UP AND DOWN WHILE THE AMP IS DOING THIS ANY IDEAS?? |
#2 |
Is the voltage pulsing on the B+ and ground terminals?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
No
#4 |
How much is the voltage dropping when it pulses?
IS the voltage pulsing on both the collector and the emitter of Q660?
#5 |
On pin 8 it will drop from 13.88 volts to 0 volts pin 4 will drop to -.68 volts
If i take the rectifiers out of the amp it will stay powerd up Do not see a Q660 Last edited by mike49504; 30th December 2011 at 06:56 AM. |
#6 |
I'm guessing that 4 and 8 are on the 494.
Reinstall the rectifiers and measure the DC voltage across the emitter resistors for each channel. Do you read anything more than 0.000 v DC on either channel?
#7 |
Found the problem R646 (10 ohm) resistor was bad
| Need help ! Pioneer GM-2200 | stuparumihairadu | Car Audio | 112 | 24th November 2011 10:36 AM |
| Pioneer GM-X962 | mike49504 | Car Audio | 1 | 2nd March 2011 11:20 PM |
| Where can i find Pioneer gm-x624/gm-x524 manuals? | gudrun | Car Audio | 1 | 22nd February 2007 02:01 AM |
| Pioneer GM-X922 | DraugDK | Parts | 1 | 13th March 2003 12:40 PM |
| Page generated in 0.08577 seconds (78.57% PHP - 21.43% MySQL) with 10 queries |
