Go Back   Home > Forums > General Interest > Car Audio
Old 10th January 2012, 03:30 PM   #21
Mote is offline Mote  Estonia
Without the solder bridge:
Transistor:
E:-0,08V
C:9,70V
B:-1,43V
Diode connected to emitter of that transistor:
-0,08V and 0V
Diode connected to base of that transistor:
-1,43V and 10,56V
With solder bridge:
E:-0,04V
C:7,31V
B:0V
-0,04V and 0V
8,63V and 0V
Tools: C1-76 o-scope, Weller WHS40, Mastech MAS830L multimeter, Mastech MY6243 LC meter, 16A supply
Old 10th January 2012, 05:36 PM   #22
The negative voltage would seem to indicate that there is a problem because all of this is on the primary side of the power supply and there are no negative voltage produced there.
The base of the transistor needs to be pulled up. The 150k resistor should be charging the cap and driving the base higher. Confirm that it's within tolerance and that you have approximately 12v on the end that's not connected to the base of the transistor.
Old 11th January 2012, 03:45 AM   #23
Damn, I should have caught it earlier. 150k resistor reads open on board and out of the board with multimeter at 200k and 2M ohm setting.
Ill replace it after work and see what happens.
Old 11th January 2012, 08:46 PM   #24
Replaced resistor and amp works without solder bridges. Thanks Perry.
Weak output on 1 channel of PPI PCX-4125 EriCCirE Car Audio 97 20th April 2011 04:34 PM
Crunch amp mike49504 Car Audio 6 22nd January 2010 06:49 AM
Need clue. R speaker static when low volume, fine loud, headphones fine. . . Help? danielwritesbac Solid State 4 30th December 2007 03:29 PM
My amp produces very little sound, how can I fix it? I love Op Ivy Solid State 4 24th March 2004 03:22 PM
Fine Woodworking and Audio Bob2 Everything Else 0 7th November 2002 03:02 PM
Page generated in 0.07637 seconds (71.68% PHP - 28.32% MySQL) with 11 queries
