Hi all, I have a 450/5 JL Audio Amp that stopped working mid-song last year. I was hoping it was just a fuse but when I unscrewed the bottom plate all I could see was madness (or genius if you know what you're doing). Wondering if JL has regular fuses I can try to swap out or if anyone can point me in the right direction. Just trying to avoid paying $180 to send it in over a fuse or something simple... Thanks in advance!!
#2 |
You need to confirm that you have sufficient power supply voltage. With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts on either the B+ or remote line, you need to check the wiring feeding whichever line is too low. If 'both' the B+ and remote turn-on lines are low and your battery is fully charged, you may have a bad ground connection.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
| JL Audio 500/5 repair advice, please | wjyoung | Car Audio | 11 | 28th September 2011 11:42 AM |
| JL audio 8w6 brought back from dead? | bluetjjason | Car Audio | 3 | 24th April 2011 01:46 AM |
| Can I run a 10 inch JL audio and a 12 inch JL audio off same amp | ash4kel | Car Audio | 2 | 8th April 2011 02:12 AM |
| JL Audio 10w6v2 or Infinity Kappa 100.3se? Audison SRX4 or Jl 300/4? | DcMaN | Subwoofers | 1 | 17th September 2010 10:28 AM |
| jl audio 1000.1 amp prblem | ampjunkielikeme | Car Audio | 24 | 11th April 2009 11:21 AM |
| Page generated in 0.06838 seconds (71.36% PHP - 28.64% MySQL) with 10 queries |
