Go Back   Home > Forums > General Interest > Car Audio
Old 29th December 2011, 05:19 AM   #1
Default Orion xtreme 3752 help
Hello, I am new to repairing amplifiers however I have been able to fix two amps with the help from reading on this board. My problem is that I have an Orion XTREME 3752 that is blowing fuses as soon as it turns on. I found 2 bad transistors 2N6491 which were replaced however the amp still blew the fuses. I then removed the new 2N6491's and powered the amp on. The fuses didn't blow like when i first removed the bad transistors. This time however I started smelling something so i turned off the power and found 2 330 ohm resistors that were burning. After I replace these resistors what else can I check? Also when i was soldering the new 2N6491's a ring fell out of the soldering point. Could this be the issue? Thanks in advance
Old 29th December 2011, 07:09 AM   #2
It looks like the layout of the drive sections is identical for both channels. Find the corresponding parts in the other channel.
If the solder pad lifted but there was no trace connected to it, it's probably not a problem. Solder from the other side. If there is no trace on either side, it could be a problem. Some of the Orion amps used 3 layer boards and the traces were buried between layers of fiberglass.
Xtreme 800 acebaker Car Audio 11 27th May 2011 12:06 AM
Orion #5 Clipped Car Audio 1 21st November 2008 04:34 AM
Orion NT 200 vs Orion 2150 SX Clipped Car Audio 3 12th June 2007 01:55 PM
Xtreme Noob - Summing Channels For Mono 3875 CarlosT Chip Amps 37 30th November 2006 12:36 AM
Page generated in 0.06509 seconds (68.98% PHP - 31.02% MySQL) with 11 queries
