Go Back   Home > Forums > General Interest > Car Audio
Old 28th December 2011, 11:13 PM   #1
Default PLANET AUDIO PA2500D
I got this in for repair..
All of the power supply fets were blown -FQP50N06
All of the outputs were also shorted..
Anyone know where to find theese or a good replacement They are
RFP40N10
They are being driver by the famous HIP4080 AIP
Old 29th December 2011, 12:26 AM   #2
Check the specs on a FQP44N10
Old 29th December 2011, 01:32 AM   #3
cant seem to find thoose parts in stock either
Old 29th December 2011, 03:13 AM   #4
Avnet
Sent from my Punch 60.2
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 29th December 2011, 07:01 AM   #5
As always, I'd recommend the IRF3710Z.
Old 19th January 2012, 03:19 AM   #6
I replaced the HIP4080 in this amp but ive seen them bad right out of the box ..
Is there a way to test to see if the HIP4080 is working correctly before i stick the outputs in this amp ?
Old 19th January 2012, 03:26 AM   #7
It's virtually impossible to have a defective semiconductor. They're all tested as far as I know. It's more likely that you missed something (a defective component that killed the IC) or mishandled the IC.
Since the high-side gets it's voltage from the oscillation of the output transistors, it's not easy to test the IC in the circuit without the FETs.
Old 20th January 2012, 05:38 AM   #8
I replaced the HIP4080 and replaced the orginal outputs (RF40N10) with
IRF3710Z's..
When i power the amp up it draws excessive current and blew 2 of the new outputs... I took the 2 shorted outputs out and the HIP4080 out..
Amp still draws excessive current so i took the rest of the new outputs out and stuck 4 of the 8 old outputs in the amp ...
Still draws excessive current with the outputs in circuit ..
Any ideas?
Old 20th January 2012, 05:44 AM   #9
I don't think this amp has any pulldown resistors. If that's true, you cannot install the outputs without the 4080 in the circuit. It will continue to blow outputs. If you applied power with the new outputs in and the 4080 out, that's why they failed or drew excessive current.
If the 4080 was in the circuit with blown outputs, it's likely that the 4080 has been damaged.
Old 20th January 2012, 06:13 AM   #10
Ok i will order a new HIP4080 and some new outputs again and see what happens
Planet Audio bb2400.1 mupto Car Audio 7 24th September 2011 10:20 AM
Planet Audio PA2250D spooney Car Audio 24 15th February 2011 04:05 PM
Planet Audio ZR300.4 o. l. t. Car Audio 25 24th May 2010 03:46 AM
Planet Audio VX2200D tdetlor Class D 0 4th February 2010 01:58 AM
Planet Audio amp rader Car Audio 3 7th November 2006 08:50 PM
Page generated in 0.09314 seconds (76.42% PHP - 23.58% MySQL) with 10 queries
