#11 |
The simple TL497 Buck regulator will do the job.
The components to the right of L1 simply need to be scaled to produce the voltage required. You are sampling the output so you want 1.2V across R5. TR1 needs to have sufficient Vce rating for output voltage as does D1 and C4. Other than that the extra voltage comes from the collapsing field of L1 so L1 will need to have sufficient inductance to produce the voltage required. In my experience just wind as many turn as you can on an RM type pot core with wire that can sustain the current required. The circuit becomes more complex at higher currents but for low current use this will do the trick. |
#12 | |
![]() From the OP - "It'll probably be a line stage amp with 12AU7's or such. But, the real challenge here is getting a B+ voltage from 12Vdc." |
#13 | |
"To err is human.. to make a real balls-up requires a computer" |
#14 |
#15 | |
I personally looked into tubes for the mobile environment a long time ago and gave up. The idea is great but there are just to many drawbacks imo. I have a plan to build a F5 for my car one day and use it on my compression horns. I just havent had the time to find a PS to use in the setup though.
http://www.caraudioconnoisseur.com/ |
#16 |
Some pics here: Anybody using a tube amp in their car?
| Another way of powering a DCX2496 in a car | djQUAN | Car Audio | 4 | 1st October 2011 05:30 PM |
| Powering car amps with power supplies | msharpe | Car Audio | 17 | 21st May 2006 08:35 PM |
| Powering Crazy Car Setup In Bedroom | JohnnyJ | Power Supplies | 115 | 6th September 2005 11:22 AM |
| Powering a car amp | soundNERD | Car Audio | 14 | 29th June 2005 03:40 AM |
| Page generated in 0.08541 seconds (77.31% PHP - 22.69% MySQL) with 11 queries |
