Go Back   Home > Forums > General Interest > Car Audio
Old 26th December 2011, 01:03 AM   #1
seankane's Avatar
Default Rockford Fosgate Punch 400.4
Hello everyone.
I have a Punch 400.4 board number PC-0954C looks to be the same board as the 400X4 transana.
I recieved the amp in with 2 channels working. The 2 channels that did not one had 26.50 vdc on it and the other had distortion, and sometimes it had a constant thumping.
I fixed the channel with the thumping, it was a combo of a broken rca shield ground pin and a faulty x-over card slot. This channel now produces audio but will not bias. If you max the bias pot fully clockwise it will draw some current but is significantely higher in adjustment than the working channels. It may be due to the new outputs, not sure. The output for this channel does look clean on the scope.
The other channel will not bias either and still has distortion.
What has been done so far:
Q414, Q419, Q315, Q319 IRF540 and IRF9540 output fets have been changed.
R463, R436, R363, R336 source resistors have been changed.
Q410 and Q310 MPS6521 bias transistors have been changed.
Q413, Q421, Q412, Q422 MPSA06 and MPSA56 driver transistors have been changed.
R449 was missing from the board due to extreme heat from the looks of the solder which was a 150ohm resistor. I replaced it with a new one.
The 4 series channel still has distortion and will not bias. It does not have any DC on the bridging terminal for this channel. Looking for some advice as where to go next.
Also if anyone has a schematic for this board that would be great too!!
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 26th December 2011, 02:01 AM   #2
Check your email.
Post again if you can't find the problem with the schematic diagram.
Old 26th December 2011, 03:31 AM   #3
seankane's Avatar
Im still having trouble. I just dont understand how the output can look clean on the scope but be distorted through the speaker. The only time the signal looks funny is well into hard clipping.
I have been testing various components vs working channels and still no luck yet.
Old 26th December 2011, 04:28 AM   #4
Are you saying that if you drive a 100HZ sine wave into the amp with a speaker or dummy load connected to the speaker terminals that the signal looks perfectly clean right up to clipping but it sounds distorted?
Old 26th December 2011, 04:34 AM   #5
seankane's Avatar
No... without a load or speaker hooked up driving a 100hz sine wave into the amp with the scope set at 10vol/div 2 ms the amp has a clean signal on the scope up until hard clipping then it looks distorted.
If you hook up a speaker to the amp and play a musical CD the sound is distorted and the higher you turn the volume the worse it gets.
I put my meter on the bridging terminal of that channel and as the volume is increased DC begins to appear and increases with the volume. There is no DC on the bridging terminal at an idle.
Old 26th December 2011, 05:13 AM   #6
Load the channel. Drive a 100Hz sine wave into it and post a photo of the distorted waveform.
Old 26th December 2011, 05:44 AM   #7
seankane's Avatar
With a load the signal is not clean. I drove a 100Hz sinewave into the amp scope setting were 10vol/div and 2 ms.
First photo is at low volume, second photo is clipping at half volume.
Old 26th December 2011, 07:39 AM   #8
Does removing D404 change anything?
Old 26th December 2011, 08:07 AM   #9
seankane's Avatar
Yes removing D404 makes the channel produce clean sound on an audio cd.
Old 26th December 2011, 08:12 AM   #10
Then the problem is likely one of the protection circuit transistors in that area (Qx16, 17 or 18). Check them all.
Rockford Fosgate Punch 500S seankane Car Audio 39 15th July 2011 05:29 AM
Rockford Fosgate Punch 800a4 seankane Car Audio 7 20th June 2011 07:15 AM
Rockford Fosgate Punch 200IX seankane Car Audio 64 12th May 2011 12:48 AM
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 04:20 PM
Rockford Fosgate Punch sub question audiomachines Subwoofers 4 18th August 2006 01:51 AM
Page generated in 0.10564 seconds (83.85% PHP - 16.15% MySQL) with 11 queries
