| Home | Forums | Rules | Articles | Store | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Please consider donating to help us continue to serve you.
Ads on/off / Custom Title / More PMs / More album space / Advanced printing & mass image saving |
Thread Tools | Search this Thread |
#1 |
diyAudio Member
i got this for repair. q216 is shorted across the first and third leg. im having a little trouble finding the data sheet.
#2 |
diyAudio Member
__________________
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
diyAudio Member
ok i have a short on u7 on the tabs of the board. i also removed the output and power supply transistors. its still in protect.
#4 |
diyAudio Member
What are 'tabs of the board'?
__________________
#5 |
diyAudio Member
oh the first two legs of u7 are shorted on the board.is it like that by design?
#6 |
diyAudio Member
You should read ~120 ohms between legs 1 and 2 of U7.
__________________
#7 |
diyAudio Member
ok i read 120 ohms. i cant get it to come out of protection.
#8 |
diyAudio Member
Is the protect LED lit brightly or dimly?
__________________
#9 |
diyAudio Member
its very dim.
#10 |
diyAudio Member
That's fairly common for amps of this type. It's probably not in protect. When it's in protect, the LED is almost blindingly bright if you look straight into it.
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| RF Attenuators (Again)! | jkeny | Digital Source | 6 | 10th February 2011 05:43 PM |
| Laser Pickup´s M52103FP RF-Amp instead of older CX20109 RF-Amp | Salar | Digital Source | 2 | 25th July 2010 05:44 PM |
| for the RF 's | tomtt | Everything Else | 11 | 9th May 2010 02:03 AM |
| Polar T1000 Assistance | keypunch | Everything Else | 1 | 8th January 2007 03:21 AM |
| Enlightened Audio Designs EAD T1000 Transport | georgehifi | Digital Source | 0 | 4th December 2005 07:21 AM |
| New To Site? | Need Help? |
| Page generated in 0.09437 seconds (74.50% PHP - 25.50% MySQL) with 11 queries |
