rf t1000
i got this for repair. q216 is shorted across the first and third leg. im having a little trouble finding the data sheet.
How much is a lot? You need to be specific. Try to think ahead and provide as much information as possible.
Is the amp producing both positive and negative rail voltage?
If you operate all of the controls through their entire range, how does it affect the noise?
If it makes a difference, which control(s) make the most difference?
the amp is producing both positive and negative rail voltage.
no control affect the noise but the gain.
the amp pulled 5amps. then went over 10amps. my meter stops at ten.
the output transistor q209.q208q207.q210 got very hot.
the two output drive transistors q205.q216 reads 100 ohms. across the 1and3 legs.
im going to pull q209.q208q207.q210.
