AMP'S PROTECTION LIGHT IS ON BUT THE AMP IS PRODUCING + - RAIL VOLTAGES THERE IS ALSO 4.44 VOLTS ON THE OUTPUTS I ALSO GET + - 12 VOLTS ON THE REGULATORS
HERES WHAT I GET ON THE 494 PIN 1:4.17 PIN 2:4.94 PIN 3:0.05 PIN 4:0.05 PIN 5:1.46 PIN 6:3.60 PIN 7:0 PIN 8:13.88 PIN 9:5.38 PIN 10:5.38 PIN 11:13.88 PIN 12:13.88 PIN 13:4.94 PIN 14:4.94 PIN 15:4.17 PIN 16:2.47 ALL OUTPUTS TEST GOOD ANY IDEAS?? Last edited by mike49504; 23rd December 2011 at 10:13 PM. |
#2 |
Outputs? Speaker terminals or output transistors? If transistors, which legs?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
The outputs FB38N20D's all test fine...
I have 4.44 volts on the speaker terminals.. |
#4 |
Is that with both meter probes on the speaker terminals?
#5 |
Yes
#6 |
any ideas what to look for next?
#7 |
What is the resistance from the RCA shield to the negative speaker terminal?
No RCAs plugged in. What is the DC voltage on pin 1 of IC103 with the black probe on the negative speaker terminal?
#8 |
No RCAs plugged in. 16.76 mega ohms What is the DC voltage on pin 1 of IC103 with the black probe on the negative speaker terminal? Dont see a IC103 They are labeld like U10 U9 ect __________________ |
#9 |
Post a photo of the inside of the amp.
| Fusion PP-AM20001 | spooney | Car Audio | 12 | 8th January 2011 09:45 PM |
| Need help Fusion PPAM4002 | trevor1320 | Car Audio | 4 | 20th June 2010 01:10 PM |
| Fusion NV AM25001 | mike49504 | Car Audio | 23 | 22nd January 2010 06:21 AM |
| Fusion Amp | Tom7227 | Car Audio | 1 | 29th May 2007 08:02 PM |
| Fusion-jazz | plysch | Music | 1 | 18th April 2004 08:27 PM |
| Page generated in 0.08100 seconds (78.63% PHP - 21.37% MySQL) with 10 queries |
