Go Back   Home > Forums > General Interest > Car Audio
Old 3rd January 2012, 12:34 AM   #51
what voltages should i look for?
Old 3rd January 2012, 01:01 AM   #52
D307 and 308 are likely the RP diodes. They should read the same as when you measure the resistance across the B+ and ground terminals.
There's no easy way to test the 4080.
Old 3rd January 2012, 01:13 AM   #53
they made very unstable readings with both polarities (swapping probes around on each)
Old 3rd January 2012, 10:49 PM   #54
the RP diodes out of circuit read .359v on diode check 18.29k ohms and OL reversed they good???
they are FR605's
Old 5th January 2012, 11:35 PM   #55
according to your diode testing procedure if it measures less than .5v and more than .9 its considered defective?
Old 6th January 2012, 02:15 AM   #56
Isn't that value given for P-channel FETs, and not diodes?
Old 6th January 2012, 10:21 PM   #57
yeah youre right duh I wasnt thinking , so they are good then
Old 6th January 2012, 11:27 PM   #58
Yes
Old 7th January 2012, 01:56 AM   #59
hmm
Old 14th April 2012, 09:42 AM   #60
richto is offline richto  United Kingdom
I work on Boss Audio all the time. If it blows fuses as soon as you apply power, without the remote connection powered then most likely you have a short circuit transistor in the PSU stage.
With these amplifiers, failure is almost always due to excessive heat caused by powering the amplifier inadequately. Too low a supply voltage will cause the amplifier to draw too much current and fry itself.
Therefore in the case of blown transistors, you should always replace the complete bank, not just the failed one as likely all transistors near by are also damaged.
It is unusual to have to replace driver stage transistors, etc. almost always it it the PSU or amplifier output stages that fail to short circuit.
Sanyo/B&O Icepower 200AC Rev.D, schematic about rev. engin., not complete finished tiefbassuebertr Class D 34 1st April 2013 01:54 PM
Lightning audio in protect. Checked usuals Justinh722 Car Audio 28 24th September 2011 11:51 PM
how to protect your audio equipment at the rainning day? Better Cai Everything Else 1 27th July 2011 01:37 PM
What do you do to protect your car audio? boxcustom Car Audio 31 1st June 2011 11:41 AM
Is this any good? Boss Audio CX1800 amp danford1 Car Audio 0 13th December 2010 06:12 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
