#31 |
The fiberglass is the material inbetween the copper layers. If it's burned away, what are you touching? A copper trace?
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#32 |
If you look in the pictures you can see It's a section of exposed copper, like a super wide trace, right under where the capacitors were. That is conductive with the inductor, as well as the speaker terminals. The black coating melted away and I believe it is a wide trace. But I am not sure if it should be conductive with the inductor and the speaker terminals.
#33 |
It's likely a copper conductor (trace) that's connected to both the inductor and the speaker terminals. That trace passes the audio signal from the inductor to the speaker terminals.
The insulating/protective coating on the circuit board (that burned away) is called solder mask.
#34 |
Ok, so It allows larger amounts of current to pass. I still read a short from one mount hole to the other where the capacitors went. Without the capacitors installed should'nt there be a break in the circuit?
#35 |
Are you reading the same thing that you read across speaker terminals?
You shouldn't use the term 'short'. Put the meter on resistance/ohms and post what you see on the meter's display.
#36 |
Your right I confused myself. I read the same as I did across the speaker terminals. 4.7 ohms. I have the capacitors on order. when I get them in the board that should change the resistance across the terminals right? I apologize for the confusion, I have never seen a meter read this way.
#37 |
What resistance do you read when you touch the probes together?
#38 |
000.0 in ohm's
#39 |
Remove the inductor to see if the resistance across the terminals changes significantly.
What make/model meter do you have?
#40 |
I have 6 ohm's across the speaker terminals. 000.0 across the inductor, and 20m ohms where the inductor was. I have a Radio Shack 22-812 Digital Multimeter with PC interface. Sorry I took a bit I had family over.
| rockford fosgate t2000-1bd blown power supply mosfets | 2sheezy | Power Supplies | 3 | 4th October 2011 07:59 PM |
| rockford fosgate t2000-1bd blown power supply mosfets | 2sheezy | Car Audio | 15 | 4th October 2011 12:50 AM |
| Tips on fixing my Rockford P1000-1bd | jamesnail | Solid State | 8 | 30th January 2010 09:56 PM |
| rockford p600.1bd amp | Cal Weldon | Car Audio | 0 | 7th September 2009 05:47 AM |
| rockford fosgate 1500 bd | mike49504 | Car Audio | 18 | 30th December 2008 07:37 AM |
| Page generated in 0.25464 seconds (100.00% PHP - 0% MySQL) with 10 queries |
