do you know if it would be okay to replace those 8 big yellow film capacitors reading 4.7uf with ones with a lower value maybe with a 3.3uf or even a 2.2uf will this alter the sound quality to make it sound warmer? i'm scared of messing up my picasso. will this make the amp more unstable in any way?
#2 |
why would you want to change them? are they leaking or something?
#3 |
yes they are, i realized this when i noticed one of the channel playing lower than the other so i swapped 2 of the yellow capacitor from the rear right channel with the 2 yellow capacitor from the front right channel and the issue moved from the rear right channel to the front right channel and fixed the rear channel. since i need to replace 2 of them i am going to just replace all of them and just wanted to know if anyone knows if changing the value will affect the sound quality or the value has to be followed or my amp will go up in smoke.
#4 |
I can't answer your capacitor question but we are about to experiment with different op-amps on a Ref Picasso and I will let you know the results. We have replaced two of the four OP275 by OPA2134 and will compare the modified channels with the original channels.
#5 |
do anyone have an explaination to why the picasso class A has those metalized polypropelyne caps with (4.7k 100v, mpa ch) if they are leaky will replacing them with solen 4.0uf 250v metalized poplypropelyne caps be ok or would it cause problems. what if i was to replace them with a solen 4.7uf 400v metallized polypropelyne capacitor would this be ok. would i need to replace them in pairs or should just replace all 8 of them. how does this amp compare to a mcintosh amp, been debating on purchasing a mcintosh. I'm on a quest in building a sq system for the past 15 years and still not successful. I'm just not satisfy with my results.
| FS- soundstream angina class d sub amp | ke4mcl | Swap Meet | 0 | 8th December 2011 10:16 PM |
| Repairing Soundstream Class A 6.0 | JLH | Car Audio | 4 | 22nd July 2011 10:09 PM |
| Soundstream Picasso 1.1700D | mike49504 | Car Audio | 1 | 2nd November 2010 09:56 PM |
| SoundStream Class A 5.0 issues | amc32 | Car Audio | 3 | 8th August 2008 05:54 AM |
| problem with soundstream class 5.2 | marko | Car Audio | 0 | 16th September 2006 09:43 PM |
| Page generated in 0.07722 seconds (73.37% PHP - 26.63% MySQL) with 10 queries |
