Go Back   Home > Forums > General Interest > Car Audio
Old 19th December 2011, 08:16 PM   #1
Default MTX Thunder801d
Replaced the input caps in this thing a few months ago but it back with different problems. Amp powers up, red light is on but no audio. There looks to be some damage to some surface mount resistors R139 R140 R142. They have some very small burn marks on them. Has anyone seen these go before and know the value?
Old 20th December 2011, 12:38 AM   #2
It sounds like the power supply may have failed. Are these the gate resistors for the power supply FETs?
If you're not sure, post a photo of the resistors and the area around them.
Old 20th December 2011, 03:43 AM   #3
They seem to be in a pre drive if there is such a thing in class D. Checked voltages on the output fets. I only see -60 vdc but the power supply seems to be generating +/- 60vdc. The fets are not shorted but maybe tomorrow I'll pull them and check them on my tracker.
Old 20th December 2011, 04:30 AM   #4
140 and 142 are likely 475 ohms. 139 is likely a 221 ohm. These values are from a 6500D which is very similar.
Carefully check the small parallel PNP driver transistors adjacent to the PZTA42 transistors.
Old 23rd December 2011, 08:02 PM   #5
Finally had a chance to look at this thing again. Removed the 2 transistor and Q116 is shorted. Any idea what I could replace them with. I wouldn't mind standing up some to92 cases if I knew the specs.
Old 23rd December 2011, 09:53 PM   #6
MMBT5401.
Old 29th December 2011, 01:46 PM   #7
Thanks for all the great info Perry. I will let you know how it goes when I get the parts in it.
MTX thunder801d fragmental Car Audio 3 16th March 2011 05:02 PM
Help MTX TA3401 Cain Car Audio 9 3rd March 2011 02:43 AM
orion hcca250r, kicker zr 1000, mmats d800.2, mtx 6500d, mtx 942, rockford punch 45, ernie cosillos Swap Meet 3 12th February 2011 11:14 AM
Help me fix MTX 152 and MTX 500D hakentt Car Audio 94 8th December 2008 06:26 PM
Page generated in 0.07738 seconds (73.20% PHP - 26.80% MySQL) with 11 queries
