diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   soundstream rubi 2500 (http://www.diyaudio.com/forums/car-audio/202713-soundstream-rubi-2500-a.html)
timwebb 18th December 2011 04:09 AM
im working on a rubi2500. the transistors in the power supply are IRF1010. i have irfz44n on hand. it rated less. but would it work?
Perry Babin 18th December 2011 04:32 AM
They won't be reliable but could be used for testing.
timwebb 18th December 2011 01:51 PM
Where can I buy these fans? I can't find any that will fit. The driver card uses a1837 and c4793.
So they are crammed on there. Is there a way to reduce the heating issue.?
Perry Babin 18th December 2011 06:09 PM
If no one else can answer your question, post a photo of the board and fan.
brandes.cm 18th December 2011 06:47 PM
What type of fan? I can get a part # for 5v we use at work, ~1.25" square.
Sent from my DROID using Tapatalk
timwebb 18th December 2011 07:06 PM
I'm at work right now so I can't put a picture up. Its the fan all power acoustic have to cool the driver card.
Perry Babin 18th December 2011 11:20 PM
You can get them from digi-key or mouser. They're 40mmx10mm. The originals were probably rated at about 5-6cfm. 9+ cfm fans are available but are a bit noisy.
seankane 19th December 2011 05:14 AM
I have several IRF1010's on hand. PM me if you cant find them.
mike49504 19th December 2011 01:27 PM
Try here:
Search result for : irf1010 - Future Electronics
brandes.cm 19th December 2011 06:48 PM
http://parts.digikey.com/1/parts/437...efb0512ha.html
Resources saved on this page: MySQL 18.75%
