Go Back   Home > Forums > General Interest > Car Audio
Old 17th December 2011, 04:50 PM   #1
Mote is offline Mote  Estonia
Default Toxic amplifier generating noises
This is Toxic TX960 amplifier.
When I received the amp, it seemed that it would be a easy fix, two blown output transistors, two emitter resistors read open. I replaced them.
I worked on it a week ago and I did not make any notes, because I thought it would be just a case of replacing transistors. So now I do not remember original symptoms, I think I had about 4V, 18V, 4V on outputs of one channel.
I measured about 1V on output of one of the opamps (number 1 on picture).
I removed the opamp and got clean audio on other three channels.
Original opamp was IL4558S-9, ofcourse local stores did not have in stock. So I replaced it with NJM4558L. It has one pin less, but the original opamp had two pins for V+ other pins are in inverted order so I could use them.
Now I get various loud noises from speaker outputs of all 4 channels. Noises change pitch/tone when I turn LPF, HPF knobs switches. Output on scope is on attached picture 2. Waveforms on various outputs of opamps are on other pictures.
Pictured 4 opamps are only for channels one and two. When I disconnect board with opamps for channels 3 and 4 I get no noises from outputs of channels 3 and 4. When board is connected and I remove opamps 3 and 4 from main PCB, then I get clean audio from channels 3 and 4.
Tomorrow I take opamps from board for channels 3 and 4 and insert them to main board, disconnect the other board and see if I can get clean audio on channels 1 and 2. So I can rule out fault in audio amplifier section of amp.
Any other suggestions what to do?
Tools: C1-76 o-scope, Weller WHS40, Mastech MAS830L multimeter, Mastech MY6243 LC meter, 16A supply
Old 17th December 2011, 10:55 PM   #2
If the noise only started when you added the non-inline op-amp, remove it to see if the problem goes away.
Old 18th December 2011, 07:10 PM   #3
When I first installed the new opamp, I made a mistake and connected -V and +V together, I had RCA cable connected to that channel at the time, that must have damaged RCA shield -> Ground trace. It was broken in two places. I fix the trace and now amp plays clean audio on all 4 channels.
circuit board smelling like toxic waste PreSapian Solid State 6 26th December 2010 09:45 AM
Zen-LA 5.1 Amplifier (based on LM3886) is making noises EagleDM Chip Amps 0 2nd September 2008 05:34 PM
generating PWM frozenpod1 Class D 3 29th August 2005 07:09 PM
Generating Phase Data MITMechE Multi-Way 0 11th February 2005 09:04 PM
Generating a constant temp with a hexfet. Circlotron Solid State 4 27th June 2002 05:55 AM
Page generated in 0.07017 seconds (76.37% PHP - 23.63% MySQL) with 11 queries
