Go Back   Home > Forums > General Interest > Car Audio
Old 17th December 2011, 01:46 AM   #1
basshead2010's Avatar
Default Diamond Audio D3 600.1
This amp is my friends. I hooked it up. It powers on like normal but you can only hear bass coming out of the sub with the volume at 40 or higher. It is distorted at that volume too. I know this isn't a good thing but I need a second opinion. I was thinking maybe the sound might of blew out part of the way but wasn't sure. If anybody has a explanation please tell me. Thanks
Old 17th December 2011, 10:58 PM   #2
Are you sure that the signal source is in good working order and that the speaker is not blown?
Old 17th December 2011, 11:15 PM   #3
Yeah everything has a good connection. The sub isn't blown. Both coils still read the right impedance and it doesn't have any coil rub or anything.
Old 17th December 2011, 11:17 PM   #4
Yeah everything has a good connection. The sub isn't blown. The coils still read the right impedance, there isn't no coil rub and its not locked up. Still smooth when you shove on it.
Old 18th December 2011, 12:55 AM   #5
If you're absolutely sure it's the amp, the fuses in the amp are OK and you want to try to repair it, the next step would be to check voltage at various points.
Old 18th December 2011, 03:10 AM   #6
I just checked the fuses and they are good
Old 19th December 2011, 06:53 AM   #7
bump
Old 19th December 2011, 08:34 AM   #8
I was waiting for you to ask what you needed to measure.
You'll have to have the amp powered up, all transistors clamped down and a 10 amp fuse in the B+ line.
Old 19th December 2011, 08:39 AM   #9
Not to be a noob but may I ask what the B+ Line is?
Old 19th December 2011, 09:21 AM   #10
The wire from the battery that feeds the B+ terminal of the amplifier.
Diamond Audio D7 allaroundsound Car Audio 0 11th December 2011 01:17 AM
Diamond Audio D3 or MB Quart DSC? MisterTedster Car Audio 2 3rd November 2009 02:15 AM
Diamond Audio HP15 jpetek Subwoofers 6 21st August 2008 08:01 PM
Audio Workshop D3 Kit lawbadman Digital Source 16 26th April 2006 02:58 PM
diamond audio m561's favoroldschool Car Audio 0 16th May 2005 09:28 AM
Page generated in 0.09417 seconds (79.71% PHP - 20.29% MySQL) with 10 queries
