Go Back   Home > Forums > General Interest > Car Audio
Old 16th December 2011, 11:51 PM   #1
ivkata is offline ivkata  United States
Default Planet audio tt1250 works but have a high pitch noise on the speaker
Ok got this amp on ebay, was sold to me as broken . the amp power on fine and dosent aper to ever been repaired . Audio is clear however there is a high pitch noise ( like jet engine noise ) that starts 1-2 seconds after the amp is powered. Noise is presented with or without rya connected ,with or without audio so i believe to be internal .this units have internal fan can the fan be the reason for the parasite noise
Old 17th December 2011, 12:02 AM   #2
and 1 min later no audio no noise now ,wtf
Opened the amp and tested the output rails I'm getting + - 54 volts witch i believe is more than enough . tested most of the op amps and they are fine , however IC111 appears to be getting -+ 54 volts as well and this is over the parts specs -KIA393P .will remove it from the board as defective by now and see why I'm getting that much power to it when the other one is getting +- 9
Old 17th December 2011, 10:50 PM   #3
You are not seeing ±54 volts on it. It's sitting on the negative rail (pin 4 connected to the negative rail) and pin 8 is 12v above the negative rail. I think you'll find only 12v if you place the probes directly on the two power supply pins for the IC.
Old 17th December 2011, 11:33 PM   #4
thanks perry i saw that as well ,my issue is that i was getting 54 v on all other legs of the op amp ,so its either my multimeter going crazy or its me . i don't have any kia393p ic i do have 4558d can i swap them out
Help with M-Audio LX4 5.1 speaker noise thezfunk Chip Amps 1 12th September 2010 07:47 PM
High pitch tone from AlephMini yoke Pass Labs 1 15th February 2009 01:40 PM
Monica 2 + gain stage; High pitch noise problem spacemen12 Digital Line Level 0 27th October 2008 03:00 AM
FS - Planet Waves Pro-Audio speaker cables t-head Swap Meet 0 18th October 2008 08:22 PM
High Pitch Noise in tweeters bigrubes24 Car Audio 2 28th April 2005 12:39 AM
Page generated in 0.06520 seconds (76.20% PHP - 23.80% MySQL) with 10 queries
