Go Back   Home > Forums > General Interest > Car Audio
Old 12th December 2011, 09:47 PM   #1
Default JBL GTO 1201.1 Problem
When playing it hard the relay kicks off and protect light comes on and protect light is on very dimly all the time any ideas? have replaced all power mosfets and all check good
Old 12th December 2011, 10:11 PM   #2
amc32 is offline amc32  United States
What is the speaker load presented on the amplifier? Do you own a scope?
...............I Hear in color.................
Old 12th December 2011, 10:28 PM   #3
4 ohms yes i have a scope
Old 12th December 2011, 10:50 PM   #4
With the amp with no speakers connected what is the dc offset voltage? Are there any irregularities on the scope in the oscilation of outputs?
Old 12th December 2011, 10:52 PM   #5
Your 4 ohm load, is it a dummy load or speaker?
Old 12th December 2011, 11:25 PM   #6
its a dual 2 ohm sub wired at 4 ohms , where do i check that , im still learning
Old 12th December 2011, 11:28 PM   #7
Are you sure that the voltage at the B+ and ground terminals isn't dropping too low?
In the original post, you mentioned the protection LED twice. Was this intended or was it a typo?
Or is the protect LED always lit dimly, even before it goes into protect mode?
Old 12th December 2011, 11:30 PM   #8
yes dimly lit with no load
Old 12th December 2011, 11:39 PM   #9
it plays thru several frequencies and never drops below 13 volts til it hits 47 hz my power supply is a 30 amp continuous dc powersupply @ 13.8 v 47 hz is the only freq that makes it cut off but the protect light gets brighter as the bass hits
Old 12th December 2011, 11:48 PM   #10
With the amp on, no load, no signal, place the black probe on pin 4 of U401. Post the voltage on the other pins.
U401
Pin 1:
Pin 2:
Pin 3:
Pin 4: black probe
Pin 5:
Pin 6:
Pin 7:
Pin 8:
What is the DC voltage on pin 4 of the TL494 on the power supply board? Place the black probe on the amp's ground terminal for this.
JBL GTO 1004 mike49504 Car Audio 1 25th July 2011 03:37 AM
JBL GTO 14001 mike49504 Car Audio 12 17th June 2011 08:35 PM
GTO 2000 (JBL) bridge question mikee55 Car Audio 15 13th August 2007 01:45 PM
Anyone got a JBL GTO 6000 ? andey Car Audio 2 5th December 2004 06:06 PM
how close r watt ratins on a AUDIOBAHN A2300HCT amp n has ne1 used it.. and a jbl gto the bass master Car Audio 7 22nd July 2004 12:18 AM
Page generated in 0.09571 seconds (75.95% PHP - 24.05% MySQL) with 10 queries
