Go Back   Home > Forums > General Interest > Car Audio
Old 20th January 2012, 03:37 PM   #41
josesony68's Avatar
Well, here are some of my measurements:
U17
Pin 1: 0
pin 2: 0
pin 3: 0
pin 4: -9.91
pin 5: 0
pin 6: 7.90
pin 7: 9.76
pin 8: 0
U5
Pin 1: 0
pin 2: 7.90
Pin 3: 8.15
pin 4: -9.91
pin 5: -0.40
pin 6: 8.23
pin 7: 9.76
pin 8: -0.93 and this measure ranged
U5 can be wrong?
Old 20th January 2012, 04:47 PM   #42
Post the voltage on U11. You shouldn't have any significant DC on pin 3 of U5.
Old 20th January 2012, 06:06 PM   #43
josesony68's Avatar
U11
pin 1: -8,04
pin 2: 0
pin 3: 1,67
pin 4: -9,90
pin 5: 0
pin 6: -7,15
pin 7: 8,16
pin 8: 9,76
Old 20th January 2012, 06:53 PM   #44
This IC appears to be defective.
Old 20th January 2012, 07:40 PM   #45
josesony68's Avatar
Okay, but this IC, I have not, I will order more parts, take me to come, eight or ten days.
Thanks for everything, Perry, and when I get the parts, I will tell what happens ...
Old 14th February 2012, 06:01 PM   #46
josesony68's Avatar
Well, today I arrived I was missing the IC (LM6172)
This is what happens when connected:
The first thing to say that the amplifier is stable, even when loaded in the output and input signal.
The speaker produces hissing, (0.7 v at terminals)
When I connect the audio signal at the entrance, distorted sound on the speaker, and bass, as if it ran only 15% of its performance.
When you turn the gain level, the hissing sound changes, there is even a point at which almost disappears.
When I switch the switch on the stage, the speaker cone gives a blow.
I think the amp works, but must have a fault in the previous section ...
What do you think Perry?
Old 15th February 2012, 10:32 AM   #47
What do you mean by "When I switch the switch on the stage"?
Old 15th February 2012, 10:46 AM   #48
josesony68's Avatar
No, sorry, must be my translator
I refer to the phase switch (0-180) which when I move it, produces a thump sound from the speaker....
Old 15th February 2012, 11:21 AM   #49
Do any of the op-amps in the preamp section have more than 0.01v difference between the inverting and non-inverting inputs? For 2-channel op-amps, check both sections of the op-amp.
Old 15th February 2012, 12:27 PM   #50
josesony68's Avatar
Okay, I'll check this afternoon.
This measure, I always do, with the black test negative ground of the amplifier, right?
O refers to a probe on pin 2 of the TL072, and the other probe on pin 3 of TL072?
Rockford Fosgate Power 851X repairing josesony68 Car Audio 32 24th September 2011 03:21 PM
Rockford Fosgate 1501bd Repairing josesony68 Car Audio 35 11th September 2011 03:24 PM
Support to repair Rockford Fosgate 1501bd amplifier josesony68 Car Audio 2 27th July 2011 07:09 AM
Repairing Rockford fosgate punch 40X2 channel help chipper Car Audio 17 26th August 2010 10:29 PM
Repairing Rockford Fosgate 250a2 03Jeep Car Audio 6 18th January 2006 02:02 PM
Copyright ©1999-2013 diyAudio
