Go Back   Home > Forums > General Interest > Car Audio
Old 17th April 2012, 09:27 PM   #101
josesony68's Avatar
Well, I have new results
I connected the potentiometer U17 as indicated in Seankane thread, I have also removed R31 and R35
No MOSFET transistor output on the motherboard
When connecting, and testing, the pins on the motherboard of the first group of eight MOSFETs, -9.70v. and 9.68 v. respectively when turning the knob from right to left.
But, to do the same with the other group of eight MOSFETs, and turn the knob, -9.92 v only appear as shown in photo
Which makes me suspect that there is any fault in what belongs to that section, but where? Any hints?
I will order more parts ... (LM6171, HCPL2211, MIC4420, etc. ...)
Old 18th April 2012, 05:07 AM   #102
You need to check the input and output of each previous component (driver IC, opto-coupler, op-amps) to see where the input and output don't change together as you turn the pot.
Old 18th April 2012, 06:01 PM   #103
josesony68's Avatar
Well, I'm here again
I have checked, U5, U6, U7, U8, U9, U10 and U15,
Turning the potentiometer all well regulated, volts positive and negative volt, at its inputs and its outputs, except the output of U15 (pin 7) and the output of U6 (pin 5) to give - 9.70 v always
I'm surprised that the latter are wrong, I have changed recently, is it possible that you are wrong? IC should I check some more? (TL 074, LM6172IM, .....)
Old 19th April 2012, 12:40 PM   #104
josesony68's Avatar
Hey, Perry, what do you think? the gould or the hameg?
http://www.ebay.es/itm/180864467380?...84.m1423.l2649
http://www.ebay.es/itm/120897679647?...84.m1423.l2649
Old 19th April 2012, 01:11 PM   #105
Sorry that I didn't see #103 earlier.
Confirm that the voltage measured directly across pins 2 and 3 of U15 are switching from 1.1v to -0.6v when you go from one extreme to the other with the potentiometer.
If that's right and the output of the opto-coupler isn't swinging to plus and minus 9v, the opto-coupler is defective. I'm assuming that the opto-coupler has approximately 18v across pins 5 and 8.
The scope with the sine wave locked on the display seems less likely to be defective. The one with only two straight traces could have several problems. Either one would should be good enough they are both in good working order.
Old 19th April 2012, 04:20 PM   #106
josesony68's Avatar
Perry quiet, do not feel, I know I'm patient and wait
I've done the checks that have told me and the voltage measured directly across pins 2 and 3 of the U15 is changing from 1.4V up to -0.68 V when going from one extreme to another with a potentiometer.
Between pins 5 and 8 is 19V
And on pin 7, there is always -9.70 V, while moving from one extreme to another with potentiometer
So I'll order a HCPL2211 (I heard that this IC, it is delicate to handle, is it true?)
Regarding the scope, most likely, I do, is to follow his wise advice, and try to stay with the Gould Ø300
Thanks again, Perry, and when you receive the parts, tell what happens.
Old 19th April 2012, 04:40 PM   #107
I don't know if it's delicate but you should treat is as it is.
Old 3rd May 2012, 09:49 PM   #108
josesony68's Avatar
Well, I got the A2211 (U15)
And, check voltages, I noticed that when you turn the potentiometer back and forth in the output of this IC, I have, -9.70 v and 7.28v is this correct?
For a comparison with the other IC (U9) I have, -9.90 v and 10.28v Do these tensions should be more similar (7.28 and 10.28)?
¿I can ride MEHSA strip with all the mosfet?
Old 3rd May 2012, 10:03 PM   #109
Don't install the FETs yet.
Measure the DC voltage on U15 with the black probe on pin 5 and the red probe on pin 8. Post that voltage.
Measure the voltage on pin 7 (black probe on pin 5 again).
Post the DC voltage on pin 7 with the pot clockwise and counterclockwise.
Old 3rd May 2012, 11:11 PM   #110
josesony68's Avatar
U15 probe pin8 red and black probe on pin 5: 19.68 v
pin7 (black probe pin5): 0.2 v
DC pin7 right: 7.31 v
DC pin7 left: -9.69 V (with the black probe to negative)
I have also checked U9
DC pin7 right: -10.89 v and swinging ..
DC pin7 left: 7.01 v and down ...
Rockford Fosgate Power 851X repairing josesony68 Car Audio 32 24th September 2011 03:21 PM
Rockford Fosgate 1501bd Repairing josesony68 Car Audio 35 11th September 2011 03:24 PM
Support to repair Rockford Fosgate 1501bd amplifier josesony68 Car Audio 2 27th July 2011 07:09 AM
Repairing Rockford fosgate punch 40X2 channel help chipper Car Audio 17 26th August 2010 10:29 PM
Repairing Rockford Fosgate 250a2 03Jeep Car Audio 6 18th January 2006 02:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
