I have almost the same problem, (white hissing noise). The only difference is after adding the new Pioneer deck to my system, I can't eliminate the hiss by turning down the volume. I found it odd that it only hisses when the key is in the ON position (turning on the dash lights etc) but in the accessory position it doesn't make any noise. Any help would be appreciated thanks!
