Go Back   Home > Forums > General Interest > Car Audio
Old 7th December 2011, 10:56 PM   #1
ivkata is offline ivkata  United States
Default PPI PC2600.2 power supply issues help needed
hello
the rookie is trying to fix nice PPI Pc2600.2 I'm seeing few issues
1 -green light comes on but the amp is not powering .all fets are tested and no shorts and no repairs in the past that i can see.At the power supply fets I'm getting 1v on the gates and 11 on the middle legs
2- one of the driver cars looks like it was getting hot -bit brownish under it
3 the mystery- one resistor is mounted on the board but not soldered r192 its between q71 and q72 transistors .it looks like it has never been soldered to the board just mounted
Old 8th December 2011, 12:34 AM   #2
Are you seeing any voltage at the rectifiers, +rail, -rail?
Old 8th December 2011, 02:38 AM   #3
1. That would generally mean that the power supply is running.
2. Does it look like the board it discolored or could it be something on the board? Is it discolored top and bottom?
3. Is there any solder on the bottom of the board? It seems like it would have fallen out if not soldered in.
4. Operating the amp without the bottom cover in place is dangerous because the transistors can overheat and fail quickly, especially if there is a problem. When troubleshooting it without the cover, install shunts on the 2-pin headers JP1 and JP4 while troubleshooting when the cover is not tightly screwed down. There are regulator transistors on each side of the amp. They will get hot and can fail even if there are no problems with the amp. Watch their temperature closely. If you do it by touch, only touch the plastic part of the transistor.
Old 8th December 2011, 03:07 AM   #4
there is discoloration on both top and bottom of the board under the driver card .light brown discoloration .soldering looks bad like cold solder will do them again
that r192 can be soldered on the top of the board only ,i dosent look like it has ever been soldered there but why the hell should someone put it there ???resistor legs are gently folded so its stays on the board but not soldered
Old 8th December 2011, 03:38 AM   #5
Since the legs are folded/bent, I'd suspect that someone was working on the amp, installed it and forgot to solder it. If the legs are bent, it could have been making good enough contact to allow the amp to work, or maybe they gave up on trying to repair it.
Old 8th December 2011, 03:48 AM   #6
i guess so as well . the outputs have + or - 32volts so I'm thinking the power side is good
Old 8th December 2011, 03:53 AM   #7
I would expect the rail voltage to be a bit higher. What is the 12v supply voltage at the amp's power/ground terminals?
Old 8th December 2011, 04:00 AM   #8
i was feeding the amp thru adjustable power supply -11 v at the time of the first test ,readjusted to 12v and the rail voltage went to 40 ,is this the correct .the other driver card have some discoloration under as well .still no audio
Old 8th December 2011, 05:20 PM   #9
Do you have a scope?
Old 8th December 2011, 06:40 PM   #10
i do not have a scope ,maybe time to buy one
Ppi pc2600.2 mike49504 Car Audio 2 30th May 2010 08:09 PM
Ppi pc2600 mike49504 Car Audio 1 28th May 2010 01:52 AM
PPI PC2300.2 power supply issues durwood Car Audio 13 26th February 2010 04:56 PM
Precision Power PC2600.2 PPI over-current proteciont mikef1897 Car Audio 0 14th June 2006 10:02 AM
Precision Power PC2600.2 PPI mikef1897 Solid State 0 13th June 2006 03:19 AM
Page generated in 0.09533 seconds (86.35% PHP - 13.65% MySQL) with 11 queries
