Go Back   Home > Forums > General Interest > Car Audio
Old 6th December 2011, 05:54 AM   #1
ivkata is offline ivkata  United States
Default blown outputs on mtx thunder 704x need substitute
Local amp shop when south and purchased 40 amps from them for dirt cheap.all amps have the original stickers "made in china '' intact and all that i peaked at have mint boards with 1-2 bad outputs -irl540n .i have some irf540n here but for sure not enough for all amps .can i use irf540n instead or not.
amps are mtx thunder 704x and 702x
i know those are not top shelf but will sell like hot bread at 50-60 each to the flea market
Old 6th December 2011, 07:41 AM   #2
and in the power supply they use irfz48n i do have irfz44n can those be used as well.
Old 6th December 2011, 11:16 AM   #3
The IRL540 is a logic level part, you would have to know what gate voltage it will see.
The IRFZ44 is a lower spec'd part, I wouldn't use it. Look for a FDP50N06 or FQP50N06 as a replacement.
Sent from my DROID using Tapatalk
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 6th December 2011, 01:22 PM   #4
irfz44n is a lower specs i got few irfz46n as well .i do have some rfp50n06 as well that i got years ago.
Old 6th December 2011, 02:28 PM   #5
The RFP50N06 is not rated for the same current as the IRFZ48N. The 48N is rated for 65amps and the 50N06 is rated at 50 amps.
I'd suggest looking at the datasheets and getting familiar with them. If the replacement parts are a good match it does not mean it will work in the amp. Some amps are very particular about the part that is used.
Old 6th December 2011, 02:47 PM   #6
so looking online for the same parts as i got 10 amps each and all have either blown power side or blown amp side .so i was able to locate the same irfz48n at 2 different prices but side offers them for 2 times less .wondering if u have purchased parts from match.... i hope u know them as I'm worried for parts quality
Old 6th December 2011, 04:18 PM   #7
I don't understand? I order from Digikey, Mouser (same price usually) and Avnet Express. Avnet would be the cheapest if they have them. I don't order from Ebay.
Old 6th December 2011, 04:23 PM   #8
Avnet has IRFZ48N and IRL540n for $.48 each.
Old 6th December 2011, 04:47 PM   #9
thank u for sharing this side with me I've never purchased parts from them
MTX Thunder 7804 Dr Zeus Car Audio 16 9th February 2011 08:41 PM
MTX Thunder 2300 spooney Car Audio 59 11th August 2010 12:52 AM
MTX Thunder 1501D spooney Car Audio 49 16th July 2010 04:55 AM
MTX Thunder 421 D mike49504 Car Audio 3 29th May 2010 05:23 AM
Mtx Thunder 250x Blown, Help bbruton Solid State 1 21st December 2005 01:37 AM
Page generated in 0.09711 seconds (74.87% PHP - 25.13% MySQL) with 10 queries
