I have a power acoustik lt-980 2. I wired it in my car hooked up the subs and nothing. I got them used and the guy showed me it was good. I suspected my RCA jacks, but checked them and they were good and also tried a good head unit that worked with an amp. The amp goes into protection mode as soon as I touch the RCA wires to the amp, and when I disconnect the RCA wire the light goes out. I have no idea what is up and really need help. Thanks so much.
#2 |
Does the power indicator light up without the RCAs?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
No and Im getting about 8v at the + terminal grounding on the screw
#4 |
8 volts may not be enough to allow the amp to turn on. You need to determine why you only have 8v.
#5 |
could a bad ground be the fault?
#6 |
Could a bad ground be at fault
#7 |
It could be anything connected to the B+ or ground terminals. I'm assuming that the battery or power supply you're using is producing at least 12v.
#8 |
Ill check the battery tonight. And B+ is the power right.
#9 |
Ill check the battery tonight. And B+ is just power right? And does it matter that the blue light by the streaker out put comes on?
#10 |
B+ refers to the positive supply connection from the power source.
| car amp power acoustik not working | jroseler | Car Audio | 9 | 8th December 2011 10:21 PM |
| Power Acoustik Amp Help | 22chet | Car Audio | 7 | 22nd February 2009 10:05 AM |
| what r your thoughts on Power Acoustik amp??? | meandean1982 | Car Audio | 10 | 21st February 2009 02:40 PM |
| Need Help With Power Acoustik LT-980/2 Amp | FallenOne | Car Audio | 22 | 6th October 2008 04:29 AM |
| Power Acoustik Amp | chadrock | Car Audio | 28 | 19th March 2008 05:37 AM |
| Page generated in 0.08915 seconds (75.61% PHP - 24.39% MySQL) with 10 queries |
