i wanted to know if these parts were interchangeable. i came across this site that cross reference parts for u. just wanted to see if it was true.
2SC4672-KTC4379
2SA1797-KTA1666
All Cross Reference Guides
2SC4672-KTC4379
2SA1797-KTA1666
There's no way to say definitively whether the sub will work or not without more information. Even with more information, it may be difficult to predict whether a transistor will work as a sub. As examples, IRF540 vs IRF540N in Rockford amps. The N version has almost identical specs but rarely works properly. In class D amps, sometimes minor changes by the manufacturer will result in FET that won't work even though the part number is identical. You need to take the time to describe how they're being used (class b or class ab audio drivers, class d audio/switching drivers, power supply drivers...). If you also list the amplifier, that may be helpful.
How are these being used?
