Go Back   Home > Forums > General Interest > Car Audio
Old 30th November 2011, 03:17 AM   #1
Default RE Audio XTX 5000.1
Any info on this amp, I have a power up issue and believe the transformer(s) are shorted. If I run with only the remote wire it won't power up the TL494. I get about .5Vdc on the VCC pin.
Outputs and rectifiers are pulled and still throws my supply into protect.
Old 30th November 2011, 12:44 PM   #2
Does it draw any current with B+ and ground connected but no remote?
Old 30th November 2011, 01:52 PM   #3
Nope, nothing excessive.
I noticed that VCC is derived from B+ and the remote wire turns on a transistor.
The nomenclature on the board seems to be wrong for the fets as well. Unless I mount the fets from the bottom.
Old 30th November 2011, 01:56 PM   #4
Now that the FETs are out of the circuit, do you have a clean signal on the gates of all of the power supply FETs?
Old 30th November 2011, 02:14 PM   #5
I will have test that out tonight.
Old 1st December 2011, 12:32 AM   #6
With all PS fets and rectifiers out I have the gate signal. I installed one supply set and I have the same issue, my supply goes to overload and shuts down.
Old 1st December 2011, 12:55 AM   #7
If the amp has 2 banks of FETs for one transformer and 2 banks for the other transformer, try uninstalling the ones you currently have installed and install the FETs in the other bank.
Do all gate drive signals go all of the way back to ground?
Old 1st December 2011, 01:22 AM   #8
The second supply powers up fine. The first supply must have an issue on the primary side.
The gate signals all go back to gnd. It is a nice clean signal.
Old 1st December 2011, 02:25 AM   #9
I can hear a high pitched squeal then my PS goes into protect. Sounds like it is coming from the transformer.
Old 1st December 2011, 10:10 AM   #10
Twist the transformer while it's trying to power up to see if the short can be temporarily cleared. If that allows it to power up, then you'll have to try to find the point where it's shorted. Often, this is where the terminal windings meet windings wrapped around the core.
Help w/ Diablo 5000 amp Tom7227 Class D 0 27th December 2009 08:15 PM
Need help with Sansui 5000 gwyz Solid State 77 5th December 2009 01:10 AM
Sansui SP-5000 Kensai Multi-Way 3 9th February 2008 01:52 PM
need help onkyo m-5000 and m-5140 ostie01 Solid State 2 5th April 2007 08:43 PM
Page generated in 0.11069 seconds (74.64% PHP - 25.36% MySQL) with 11 queries
