Go Back   Home > Forums > General Interest > Car Audio
Old 26th November 2011, 10:24 PM   #1
Default lanzar vibe 230 minor issues
I recently bought a lanzar vibe 230 2 channel amplifier, it seems to work fine and sounds good. Just bought it because my HU leaves alot to be desired in the loudness department.
I have it connected in stereo mode @4ohms, I set my gain with a DMM to 14 volts for around 50watts of power to each speaker. I did this with a 1khz tone.
I set the gain off the right channel, but figured I would check the left also, the left channel is reading about 12.8-13volts while the rights reads about 14-14.5 volts AC.
I'm assuming this is abnormal, if it is, please tell me how to correct the issue, I also think this may be a side affect of being a cheaply made amp.
Old 26th November 2011, 10:25 PM   #2
Please delete, accidental double post
Old 26th November 2011, 10:43 PM   #3
That's only ~1dB which is inaudible.
Old 27th November 2011, 03:42 AM   #4
ppia600 is offline ppia600  United States
Use a "y" rca splitter to the input of the amp and use only one output from the deck into the splitter. This is to be sure you get exactly the same input level into both channels of the amp. (only when testing) It may just be an issue of slight channel db difference in the actual audio cd or tone generator.
Don't worry... you can always turn the gain down!
Old 3rd December 2011, 12:56 PM   #5
Or wire the "louder" channel to the driver furthest away from you
lanzar vibe 230 minor issues grandam88 Car Audio 1 26th November 2011 09:32 PM
Lanzar Vibe 256 mike49504 Car Audio 1 12th August 2011 03:27 AM
Lanzar Vibe 1800D Problems. Help please? :) vexed Car Audio 7 23rd January 2011 08:58 PM
Lanzar vibe 266 bobomohundro Car Audio 1 31st August 2009 07:25 PM
Lanzar Vibe 1800D Problem, please help! manni Car Audio 3 13th October 2006 10:20 PM
Page generated in 0.07926 seconds (72.10% PHP - 27.90% MySQL) with 10 queries
