Go Back   Home > Forums > General Interest > Car Audio
Old 26th November 2011, 09:36 PM   #1
timwebb is offline timwebb  United States
Default parts question
im rebuilding a driver card and i cant find a data sheet on this ic. it has 45800 jcr027a on it?
Old 26th November 2011, 09:37 PM   #2
It's likely an NJM4580D. They rarely fail if this is one of the clone amps.
Old 26th November 2011, 09:38 PM   #3
yes. power acoustic 3000ab. an older one.
Old 26th November 2011, 09:40 PM   #4
These rarely need anything more than replacing Q124 and Q125. If you have the DVD, read the Generic Class D - Type 2 page.
Old 27th November 2011, 12:24 AM   #5
ok. i got the amp working. i pulled out the old power bass to to compare some reading since its the same amp. i came across an ic.kia393p that receiving 50v. the max is 18-36. could that have been the issue?
Old 27th November 2011, 12:49 AM   #6
The 393 is likely on the negative rail. Measure the DC voltage with the black probe on pin 4 and the red probe on pin 8.
Old 27th November 2011, 12:54 AM   #7
one reads 25v+ the other 0.5v+
Old 27th November 2011, 12:57 AM   #8
How can you have two voltages with the probes on the points as described?
Old 27th November 2011, 01:20 AM   #9
oh there are two of them a forgot to mention the other one..
Old 27th November 2011, 02:58 AM   #10
Did you place the black probe on pin 4 of the IC that you were measuring the voltage on?
Which one had 25v?
First Project parts question Fivetide Parts 2 2nd August 2011 08:52 AM
F-5 parts question? semi932 Pass Labs 11 14th May 2011 12:10 AM
Parts question mike49504 Car Audio 2 28th December 2010 07:08 PM
Parts Supply Question ?? unohu69 Parts 6 5th December 2008 06:57 PM
PARTS PARTS PARTS!!! Infocus Powerview 820, triplet, ballast, light, power supply!!! marioinla Swap Meet 1 31st August 2004 04:22 PM
Page generated in 0.11246 seconds (71.64% PHP - 28.36% MySQL) with 11 queries
