Hi.I need help to find out components on the bord of Rockford punch 60x2.I know q6,q7 MTP50N06V and you ken replace with MTP50N06V.
But CR1: FEN16BT 9612 CR2: 9629 U1610 These are OEM parts. I can't find replacement for those.If some one know??????? |
#2 |
The MTP should be a good substitute. The others rarely fail
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
cr1 and cr2 May be wrong numbers.Thats what i need.I need the part numbers.
#4 |
I don't have any information on this amp. You can get the schematic diagram from Rockford tomorrow.
If the solder connections are original (flow soldered, not hand soldered), the parts are going to be the correct/original parts.
#5 |
The parts on the board original but they blow out.I cant read information from them.
#6 |
The rectifiers are likely OK. Why do you think they're blown?
#7 |
They blow out like charcoals they explode .
#8 |
Are CR1 and CR2 are the rectifiers. Are they physically burned? The amp isn't likely to be able to produce enough power to burn them.
#9 |
No physically.Looks like amp has enough power.All i need part numbers.
#10 |
The FEN.. is equal to an MUR1610CTR. The other is an MUR1610CT.
| Rockford Punch 60x2 DSM | Dr Zeus | Car Audio | 29 | 26th November 2011 12:24 AM |
| Punch 60X2 | seankane | Car Audio | 10 | 22nd November 2011 03:37 AM |
| Rockford Fosgate Punch 240x4 DSM | seankane | Car Audio | 33 | 3rd May 2011 02:11 AM |
| Punch 60X2 RT SP distortion | Deadly Sones | Car Audio | 4 | 21st March 2011 03:55 AM |
| Rockford punch 100 dsm | mike49504 | Car Audio | 1 | 13th December 2009 12:41 AM |
| Page generated in 0.08738 seconds (78.49% PHP - 21.51% MySQL) with 10 queries |
