Go Back   Home > Forums > General Interest > Car Audio
Old 23rd November 2011, 01:35 AM   #1
Default PPI PCX-2400
Working on this amp, right channel has +19Vdc on it and the left has -17Vdc. The left channel has the top part clipped off. The right channel has a signal riding on a dc level.
Reading other threads I found a schematic for the ceramic boards, what should the signal coming into pin 3 and 4 be.
Attached is a photo of the pc board. Are the drivers Q9, Q10 on the ceramic board?
Old 23rd November 2011, 01:47 AM   #2
Measure the voltage again but this time, place the black probe on one of the non-bridging speaker terminals.
The signal on pins 3 and 4 should be audio with essentially no DC.
Do you have the proper supply voltage on both power supply pins of the op-amps?
Do you have the proper supply voltage on both power supply pins of the driver board?
Do you read 100 ohms for each placement (A and B) on the following image?
http://www.bcae1.com/temp/ppidriverb...roverlay01.swf
Old 23rd November 2011, 02:01 AM   #3
+20Vdc on right channel
-4Vdc on the left
L+ to R- is the bridged terminals I believe.
+-13 on the op-amps
+-60 on pins 1 and 15
The right channel has no 100 ohm readings and the left channel "B" reads 100 ohms only.
Old 23rd November 2011, 02:19 AM   #4
Install a 100 ohm resistor as is shown for the open resistor.
You can determine which ones are the non-bridging terminals by finding the ones that read 0 ohms between them.
Old 23rd November 2011, 02:49 AM   #5
The left channel is functioning now.
The right channel is sitting with 55Vdc on it and the ceramic module is getting extremely hot. This channel has the signal riding on a dc level on pins 3 and 4 also.
Old 23rd November 2011, 02:59 AM   #6
Check the small predriver transistor on the top right corner of the driver board. Is it shorted or leaking?
Compare to the other board if you can't tell if it's leaking.
Have you checked the large transistors on the driver board?
Old 23rd November 2011, 03:06 AM   #7
Looking at the pic you sent, the two directly above the large transistors? Comparing between the two boards, 3 of 4 measure shorted from B-E(two pins on same side). I could have the probes touching though.
Old 23rd November 2011, 03:26 AM   #8
MMBTA06 and MMBTA56 should sub fine for these parts, correct?
Old 23rd November 2011, 04:46 AM   #9
Yes. I've used those as subs.
Old 23rd November 2011, 12:26 PM   #10
Would hot air with solder paste be the best way to solder these down?
PPI PCX Series Heatsinks? Rabbi Car Audio 6 19th February 2011 05:25 AM
ppi pcx 1250 problem 3nCod3R Car Audio 6 18th October 2010 04:22 PM
Ppi pcx 1250 mike49504 Car Audio 4 17th September 2010 06:26 PM
PPI PCX-2200 manual needed skooter Car Audio 4 24th November 2007 12:27 PM
repairing PPI PCX-2200 redblaze Car Audio 19 7th March 2007 12:31 AM
Page generated in 0.09194 seconds (79.64% PHP - 20.36% MySQL) with 11 queries
