Go Back   Home > Forums > General Interest > Car Audio
Old 22nd November 2011, 10:19 PM   #1
Default Kicker SX750.1
Anyone know the part number or value of D9 and D10. They are both dual diodes soldered in series. They are in the +15 and -15 volt supplies. Once again this is a Kicker SX750.1
Old 22nd November 2011, 10:48 PM   #2
If no one else answers this, post a photo of the diodes.
Old 23rd November 2011, 07:42 PM   #3
Hope these are okay. My camera is not the greatest.
Old 23rd November 2011, 10:41 PM   #4
fcruz is offline fcruz  Brazil
schemes have the sx650.1 sx1250.1 and will be serving you for
Old 23rd November 2011, 10:47 PM   #5
Sorry fcruz, I don't understand.
Old 23rd November 2011, 11:13 PM   #6
I have diagrams of models and sx650.1 sx1250.1 think you should serve to
Old 23rd November 2011, 11:28 PM   #7
Are they defective?
If they're connected between the base of the regulator's pass transistor and ground, they're likely equal to a 15 or a 16v zener. They may have used two of them if a single diode was overheating (and possibly falling off of the board).
The user carampsguru could probably tell you definitively what they are.
Old 24th November 2011, 11:45 AM   #8
Yes, they are both shorted and possibly the transistor also. I'm not going any deeper into the amp until I find out what the diodes are. No need if I can't get them.
Should I send carampsguru a message or wait for him to read the post?
fcruz, I don't know if the SX650.1 would use the same diodes. If you would send the diagram I will check it out.
Thanks to both for your time and trouble.
Old 24th November 2011, 12:11 PM   #9
I don't think that carampsguru visits often. It has taken a while for him to reply when I've sent him PMs in the past.
Did you check the connections I described to see if they were connected that way?
Do the emitters of the regulator transistors connect directly to the power supply pins of the audio op-amps?
Old 24th November 2011, 01:46 PM   #10
I'm not in the shop right now. I'll check in a little while and post back.
kicker box xlcjw72 Subwoofers 1 26th March 2011 12:12 AM
KICKER KX600.4 bdgf2004 Car Audio 26 8th February 2011 04:02 AM
kicker kx450.2 timwebb Car Audio 21 1st July 2010 03:52 AM
I need help with a Kicker DX700 chipper Class D 5 8th January 2009 07:45 PM
Page generated in 0.08909 seconds (85.16% PHP - 14.84% MySQL) with 11 queries
