Go Back   Home > Forums > General Interest > Car Audio
Old 23rd December 2011, 02:02 AM   #51
RiLoWa is offline RiLoWa  United States
RiLoWa's Avatar
Slow down and don't get ahead of Perry's direction. There are several things that you needed to check BEFORE you put in the IRF540's, some he has already told you and some he will. These JL amps can be a pain in the rear if you're impatient.
Q504 - Q507 are the outputs, IRF540's. If you have them installed, you should carefully remove them to continue on.
Once removed, recheck all the IRF540's ensuring they are still good. Visual inspection is of no use, use your meter.
Look closely for solder bridges where you have done some soldering work, use your meter to verify there are no shorts everywhere you have been.
Then go back and answer post #46.
Tools - 1. TPI Scope Plus 440 2. B&K 2125 20MHz Dual Trace 3. Sorensen DCR20-50B 4. B&K 4011 5MHz Function Generator 5. Weller WESD51
Old 28th December 2011, 12:58 AM   #52
Hell I have the same problem. My 500/1 turns green when powered up but absolutly no audio output. Mine has absolutly no burnt resistors or transistors, I think it might be the power supply. How can I check it or the rail voltage?
Old 28th December 2011, 03:37 AM   #53
Start a new thread.
JL Audio 500/1 v1 Rev. 10 Board RiLoWa Car Audio 40 11th October 2011 02:19 AM
JL Audio 500/1 v1 Rev. 10 Boards #2 RiLoWa Car Audio 108 6th October 2011 03:18 AM
WTB: JL Audio Slash Series Power Terminal Plastic Seperator Part RiLoWa Swap Meet 0 4th June 2011 03:30 AM
Help with JL 500/1 2nd one nsxxtreme Car Audio 51 7th March 2008 02:17 PM
FS: JL 500/1 ($500 CAD located in GVA) Dynamix Lude Swap Meet 0 27th October 2004 03:21 AM
Page generated in 0.06542 seconds (72.02% PHP - 27.98% MySQL) with 11 queries
