Does anyone know the value of the Gate resistors for the power supply fets??
#2 |
39.2 ohms
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
will 47 ohm resistors work ?? Or do i need something closer to the orginal value?
#4 |
It may work but if you have to use a sub, go a bit lower.
#5 |
would a 34 ohm work better??
#6 |
I'd use that instead of the 47 ohm.
#7 |
do you know the locations of the power suply drivers?
#8 |
They are the PZTA56s near the small driver transformer.
This amp doesn't have the same type of drive circuit that you see in most amps.
#9 |
Will legs 1 and 3 apper to be shorted in this amp?
#10 |
You're likely reading the 10 ohm resistor on the driver transistor.
| MTX Thunder 6500 D | mike49504 | Car Audio | 4 | 21st July 2011 11:01 PM |
| MTX Thunder 2160 | Rabbi | Car Audio | 5 | 14th March 2011 09:45 PM |
| MTX Thunder 2300 | spooney | Car Audio | 59 | 11th August 2010 12:52 AM |
| Mtx Thunder 2300 | vypr | Car Audio | 35 | 21st September 2006 07:35 PM |
| MTX Thunder 6152 Help | Ankst | Car Audio | 0 | 27th November 2005 05:21 AM |
| Page generated in 0.09890 seconds (77.00% PHP - 23.00% MySQL) with 10 queries |
