#31 |
Hi all, i have replaced the output transistors with a matching sets of TIP35 and TIP36.
Now this amp was testing ok before with the odd outputs, so i plugged it in and it fired up for around 30 secs with only a 10amp fuse for testing. It then blew the fuse, i replaced it and it blew even without the volume up at all. I unplugged it and 2 of the new outputs were blown, i replaced them with 2 I removed earlier, reconnected and it blew the fuse again. The amp will accept the power leads fine, and it blows the fuse about 3 secs after the amp turns on. The power transisters are ok, and the output transisters are fine as well, Where should i be looking |
#32 |
Were the original transistors TIP35s/36s?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#33 |
Yes, the difference is that the new ones have a 220 insulated case, still with the exposed rear. i have maintained the insulation behind the TIP35/36 and only test clamped. I will try replacing the TIP35/36 back to the mismatched set and test, as these tested ok before. |
#34 |
I replaced the TIPs and its going ok. The amp has promptly blown my sub once i got the fuses in and wound it up. Now the sub rattles. I will replace it and try again.
| in-room frequency response & transient response | MCPete | Multi-Way | 1 | 8th October 2011 06:31 AM |
| Response 6.5" woofer from Jaycar | poeee | Multi-Way | 6 | 10th December 2004 10:56 AM |
| Brand New Jaycar Response 10" Woofer F/S | swin1 | Swap Meet | 0 | 26th August 2004 06:45 AM |
| Doubts on Phase Response and Frequency Response | dumrum | Multi-Way | 11 | 5th April 2004 10:39 AM |
| JayCar Response 12" 150 WRMS Active Subwoofer for sale | NicolasGaal | Swap Meet | 1 | 6th January 2004 11:51 AM |
| Page generated in 0.07306 seconds (69.19% PHP - 30.81% MySQL) with 11 queries |
