Punch 40 DSM PC-0001-A REV A
I have a punch 40 dsm I am working on and it has no output. It came in with a burned up power supply. I repaired the power supply and all is well with that. The amp is producing 46.1 vdc rail voltage The op-amps have positive and negative voltage of 11.61 vdc on pins 4 and 8. The regulators are out putting fine. There is no DC on the bridging terminals. I have clean audio on pins 1 and 7 of the op-amps. The capacitors on the input board dont seem to be leaking or smell funny. The output fets are getting rail voltage but no audio signal. I have clean audio on both sides of C202. I have no audio on either side of C102. Pin 1 of HB1 has +12 vdc Pin 2 of HB1 has -12 vdc One thing I thought I would mention: HB101 pin 9: -3.104 vdc HB101 pin10: -7.26 vdc HB101 pin11: -10.85 vdc These pins should all have 0.000 vdc HB101 pin25: 0.000 vdc should have 3 vdc HB101 pin28: 0.000 vdc should have 3.6 vdc HB201 pin25: 0.300 vdc should have 3 vdc HB201 pin28: -0.200 vdc should have 3.6 vdc I dont know if this helps any but I am just wondering where I should look next?
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch Last edited by seankane; 17th November 2011 at 05:09 AM. |
#2 |
Does the bias control allow you to bias the outputs on?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
NO neither channel will bias nor will the bias turn on either output.
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch |
#4 |
Do you have the negative 12v on R102?
#5 |
Yes -11.95 vdc on both sides
#6 |
Did you replace the driver boards?
#7 |
No not yet should I do so?
Also not 100% sure on the orientation of the new boards as they are a different revision and dont look the same. Both new and old boards having writing on them wondering if I should install the new boards with the writing on the same side as the old boards. The ones I will be using are the same as I sent you. Any tips for that?
#8 |
On the driver board, pins 4 and 5 go directly to the base and emitter of a transistor. That should give you the reference you need.
Correction. That's pins 4 and 5.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links Last edited by Perry Babin; 17th November 2011 at 06:23 AM. |
#9 |
Ok I was just going to ask that, got it. Thanks Perry. From what I have described does it sound like a possiblr driver board issue? If so Why would both boards be affected? Could the power supply failure have something to do with it?
#10 |
Yes. I'm assuming that you've checked the various resistors between the board and the outputs. The supply voltages are all seem to be OK. I don't see anything else that could cause the symptoms you described. Replace one and recheck that channel before replacing the other.
| PUNCH 4080 DSM | bdgf2004 | Car Audio | 4 | 21st March 2011 07:45 AM |
| punch 40 dsm | bdgf2004 | Car Audio | 10 | 11th January 2011 12:03 AM |
| Rockford punch 100 dsm | mike49504 | Car Audio | 1 | 13th December 2009 12:41 AM |
| punch 100 dsm question | ben04srt | Car Audio | 32 | 7th December 2009 12:38 AM |
| punch 60 dsm getting warm | ben04srt | Car Audio | 5 | 3rd June 2009 10:37 PM |
| Page generated in 0.09360 seconds (78.48% PHP - 21.52% MySQL) with 11 queries |
