diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   JL Audio 500/1 (http://www.diyaudio.com/forums/car-audio/200560-jl-audio-500-1-a.html)
mike49504 15th November 2011 03:03 PM
JL Audio 500/1
Got another 1 of theese in for repair..
Dose anyone know the value of R157 ?
Its located by all the caps in the output section
Perry Babin 15th November 2011 08:35 PM
Which rev?
mike49504 16th November 2011 02:04 AM
REV 11
Perry Babin 16th November 2011 02:24 AM
Are you sure it's R157?
There's an R517. It's 10 ohms.
mike49504 16th November 2011 07:14 PM
sorry my mistake it is R517
mike49504 21st November 2011 09:27 PM
DO you happen to know the value of C501 Its also missing
Perry Babin 21st November 2011 09:42 PM
Probably a 220uF@63. That's what the rev3 has. It's the same as the group of 7 on the other side of the rail cap.
mike49504 21st November 2011 09:47 PM
Thanks..
Ive replaced the following :
R157
R515
R156
C501
All other resistors in that general area check fine..
The outputs were also missing out of this amp..
Besides checking the drivers for the outputs do i need to cheack anything else before installing the new outputs and powering it up ?
Perry Babin 21st November 2011 10:18 PM
Since it appears that someone else has attempted to repair it, I'd suggest checking the drive signal before installing the outputs.
To do this, you'll need to solder a jumper between pins 1 and 2 of the 8-pin op-amp next to U512. That should make the drive signal appear on the low side. To make the signal on the high side visible, you'll likely have to solder a jumper between legs 2 and 3 of Q505. Be sure that both jumpers are removed BEFORE installing the outputs.
mike49504 21st November 2011 10:44 PM
What would i set the scope to to check the drive signal ?
And do i touch the pad for the gate leg of the outputs?
Copyright 1999-2017 diyAudio
