#21 |
Does it look like the output filter inductor has overheated? Look carefully.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#22 |
It appears to still look new no signs of overheating
#23 |
Recheck the outputs.
Did you check the drive signal on the gate pads of ALL 4 outputs?
#24 |
Ok back to this amp..
I just bought a new probe for my scope .. I get no drive signal ( square wave) at any of the gate pads for the outputs.. |
#25 |
Post the DC voltage on all pins of all 4 outputs.
#26 |
Q504
Leg 1:0.3 Lrg 2:82.0 Leg 3:0.6 Q505 Leg 1:1.28 Leg 2:0.6 Leg 3:0 Q506 Leg 1:0 Leg 2:0 Leg 3:0 Q507 Leg 1:0 Leg 2:82.2 Leg 3:0 |
#27 |
What have you done to the amp other than installing the outputs and removing the jumpers since you saw 4 good drive signals?
#28 |
Nothing at all..
#29 |
Do all of the audio op-amps have positive and negative supply voltage?
Is the amp in protect mode? Do you see a pulse of DC on any of the speaker terminals when you power it up? Have the scope probe on the speaker terminals when you apply remote and continue watching for about 10 seconds after applying remote voltage.
#30 |
On pin 4 of all op-amps i get 0.62 volts
On pin 8 of all op-amps i get 1.28 volts Protect light is not on but the low ohms light is on all the time along with the power light.. On both + speaker terminals i get 0.08 volts on start up On both negative speaker terminals i get 0.66 volts on start up |
| JL Audio 500/5 repair advice, please | wjyoung | Car Audio | 11 | 28th September 2011 11:42 AM |
| JL Audio 500/1 | mike49504 | Car Audio | 55 | 23rd September 2011 05:26 AM |
| Jl audio 500/1 powers on with low audio out help needed | ivkata | Car Audio | 29 | 19th August 2011 12:21 AM |
| JL Audio 500/1 | mike49504 | Car Audio | 1 | 15th August 2010 09:02 PM |
| jl audio 500/1 | megael9 | Car Audio | 12 | 28th May 2010 11:01 PM |
