JL Audio 500/1
JL Audio 500/1
Old 21st November 2011, 09:46 PM   #11
Perry Babin is offline Perry Babin  United States
Start with the scope set to 5v/div and 5uS. Adjust from there.
Yes.
Old 21st November 2011, 10:09 PM   #12
mike49504 is offline mike49504  United States
What is the waveform suppose to look like on this amp ?
All i get is the trace line with vertical lines when i touch the gate pads
Old 21st November 2011, 10:19 PM   #13
You should see something like the attached image.
Old 21st November 2011, 10:29 PM   #14
Ok ..
Will the low ohm's led light since there are no outputs in circuit or is there another problem??
Old 21st November 2011, 10:34 PM   #15
I don't know.
Do you see that waveform on all 4 transistors?
Old 21st November 2011, 10:39 PM   #16
Yes i see the waveform on all 4 transistors and they look just like the image..
So i solderd in new outputs and powerd it up amp idles perfectly but the low ohm's light is still on..
Old 21st November 2011, 11:09 PM   #17
Does it produce audio?
Did you desolder the jumper on the IC?
Old 22nd November 2011, 12:45 AM   #18
I took the jumper off the IC..
Amp doesnt produce audio ..
Old 22nd November 2011, 03:56 AM   #19
Do you have rail to rail oscillation on the outputs?
Old 22nd November 2011, 07:51 PM   #20
Do you have rail to rail oscillation on the outputs? NO
JL Audio 500/1Hide this!Advertise here!
JL Audio 500/5 repair advice, please wjyoung Car Audio 11 28th September 2011 11:42 AM
JL Audio 500/1 mike49504 Car Audio 55 23rd September 2011 05:26 AM
Jl audio 500/1 powers on with low audio out help needed ivkata Car Audio 29 19th August 2011 12:21 AM
JL Audio 500/1 mike49504 Car Audio 1 15th August 2010 09:02 PM
jl audio 500/1 megael9 Car Audio 12 28th May 2010 11:01 PM
