Go Back   Home > Forums > General Interest > Car Audio
Old 15th November 2011, 12:37 PM   #1
Default CROSSFIRE XP600D need PWM DLI4060B ic
Need PWM output ic DLI4060B 24 pin is this a lost cause amp ?
Old 15th November 2011, 12:49 PM   #2
pergo is offline pergo  Italy
rarely it fails.
Look at the IR2113 beside. It often fails
Old 15th November 2011, 01:02 PM   #3
Thanks .
Old 16th November 2011, 02:39 AM   #4
There is no IR2113, heres a pic of the output side, negative output mosfets don't have voltage -6.0V drain. Positive mosfets have 46 volts on the drains .
Old 16th November 2011, 03:38 AM   #5
With the FETs in or out of the circuit?
That IC is fairly well isolated from the FETs in most amps. Check the driver transistors and the diodes in that area.
Old 16th November 2011, 03:49 AM   #6
FETs were out out circuit . Ok will check .
Old 16th November 2011, 03:54 AM   #7
Does the amp use N and P-channel outputs or all N-channel outputs?
Old 16th November 2011, 04:18 AM   #8
Yes both N and P channel output fets.
Old 16th November 2011, 04:35 AM   #9
If it uses N and P outputs, the drains should be directly connected. Check for broken inductors, open traces, bad solder connections and pulled vias.
Old 22nd November 2011, 01:27 PM   #10
I installed the output fets and the when I power up the amp , it draws 20 amps of current . Plus I was rereading this thread, the 640s gate pins had +6 volts not -6 volts . This has to be why the amp goes red line full amps . Bad drivers but they look good ? Oh and Perry like you said about lnductors the power supply transformer was making a high pitch noise but stopped. I tryed powering the amp and twisting on all inductors but no good , fuse would short out still . Power supply fets heat up and only 640s not 9640s .
Crossfire bmf1000d jordan_ciaramit Car Audio 1 8th September 2011 02:23 PM
Crossfire CFA602 mike49504 Car Audio 18 12th November 2010 07:01 AM
simple ic for 0-100% duty cycle PWM sss Power Supplies 6 2nd June 2010 01:34 PM
push-pull PWM IC chimi Power Supplies 19 4th September 2008 09:32 AM
Need HELP for Crossfire VR4000D JoergST Car Audio 2 4th December 2006 12:13 PM
Page generated in 0.09709 seconds (76.17% PHP - 23.83% MySQL) with 11 queries
