Go Back   Home > Forums > General Interest > Car Audio
Old 12th November 2011, 06:16 PM   #1
Default How do you test the RCA sub outputs on your head unit?
I have a problem with my sound system I just finished installing last weekend in my car and I got the amp to turn on but nothing was coming from the subwoofer... So i tested all the lines and made sure it was grounded well and even brought the amp to get tested to make sure it was sending a signal out to the sub at best buy and the amp works... The guy there said make sure your subwoofer setting is turned on (on the Headunit) which I made sure and still nothing... My last idea is that maybe the RCA Subwoofer outputs on the back of my Pioneer DEH-6000UB that lead to the amplifer are bad... whats the easiest way to test this out using a Multimeter? or any other suggestions that I may have to try?
Thanks for any help you may be able to provide!
Old 12th November 2011, 07:34 PM   #2
Have you tried using the signal from one of the other RCA outputs on the head unit to confirm that everything other than the head unit is working properly?
Old 12th November 2011, 08:03 PM   #3
I'll try that now, so I guess try both the front and back speaker RCA outputs and try that, is there anything else I can try while I have the head unit out to confirm that this might be the problem? I mean I don't want to have to buy a new head unit cause I'm prolly buying a new car in less then a year but its that's the problem then I'll see what I can find on Ebay for cheap.
Old 12th November 2011, 08:58 PM   #4
No go... I tried all 3 sets of RCA outputs and messed around with every setting I could think of and even busted out the online owners manual to see if it could be something else... Is there any way to test the RCA cables plugged into the headunit with a multimeter and see if I get any signal out of them?
Old 12th November 2011, 09:08 PM   #5
There's no point in trying anything else until you try what was suggested.
Old 12th November 2011, 09:15 PM   #6
I did... still nothing...
Old 12th November 2011, 09:25 PM   #7
Do the other outputs work when driving your other amps?
Old 12th November 2011, 09:35 PM   #8
Have the 4 car speakers running off the head unit (no amp attached, which is how it is stock well except with an aftermarket headunit) and the external amp is running my subwoofer and the RCA cables are suppose to send the signal out from the head unit to the amp to drive the sub, but nothing is coming out...
Old 12th November 2011, 10:09 PM   #9
Check the shield ground on the head unit.
RCA Shield Repair
Old 12th November 2011, 10:23 PM   #10
try changing rca cables
Bad/Open RCA Shield on Pioneer DEH-P7100BT Head Unit paulieb81 Car Audio 28 25th February 2010 02:59 PM
head unit basenjifan Swap Meet 0 24th September 2007 06:58 PM
head unit problem.No output through interior speakers but rca outs work fine spooney Car Audio 2 1st January 2007 11:08 AM
Head Unit VoLCoM Car Audio 4 31st October 2005 02:51 PM
no more rca jacks on head unit brihark Everything Else 0 18th December 2004 08:53 AM
Page generated in 0.10177 seconds (80.59% PHP - 19.41% MySQL) with 10 queries
