#11 |
i got the amp to power up and play for one channel. i was looking for these parts but they are not stocked or i have to buy in bulk. the transistors are in the output driver section of the amp.. 2SC2631-2sC2235
#12 |
The following is supposed to be a cross for the 2235. It may be a suitable replacement for both.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#13 |
would the MPSA42 work?
#14 |
The pin configuration is wrong. Legs 2 and 3 must be swapped. Make sure that the legs aren't touching.
This should be OK for testing to determine if the amp has other problems. The original transistor (2236) is a 1w transistor so the A42 may overheat and fail prematurely.
#15 |
i got the original part. now i have the amp back together and it plays fine for about fine minutes. then it stops playing. the amp stays on but the relays clicks. the bias has been moved from the previous repair. this is the back of the board. for the bias.
#16 |
If you look at the waveform on the output transistor (leg 3), do you have a clean signal there after the relay clicks?
| Class D Kenwood Excelon 401m HELP PLEASE | whitetiger88101 | Class D | 1 | 25th August 2011 06:20 AM |
| Kenwood Excelon HU clipping | SirGalihad | Car Audio | 4 | 17th June 2010 09:20 PM |
| Kenwood excelon kdc x717 ribbon replacement | Pjw350 | Car Audio | 0 | 3rd April 2010 01:48 AM |
| lanzar vctbs8 + dual xpa4100 + kenwood excelon XXV-05V | kbkraft | Car Audio | 0 | 28th February 2009 04:52 AM |
| kenwood excelon amp over heats to 203F | mattsoft | Car Audio | 4 | 21st September 2005 12:54 PM |
| Page generated in 0.09322 seconds (79.44% PHP - 20.56% MySQL) with 11 queries |
