Go Back   Home > Forums > General Interest > Car Audio
Old 9th November 2011, 03:41 PM   #1
Default PPI PCX1250 NEED help on transistor outputs
I have a PPI PCX1250 and need to know where the TIP35c and TIP36c
transistors go. Bought it for $20 off E-bay, and it came without the outputs. Anyway If someone can tell me if It's setup like all TIP35c's on one side and all TIP36c's on the other side, which side do they go on. I figured you good people on here would know faster than me trying to track it down. Thanks.
Old 9th November 2011, 05:01 PM   #2
I don't have any information on this amp but you can determine where the NPN and PNP outputs go using your meter.
On each side, does the solder pad for the 3rd leg of each of the output transistors read ~0 ohms to each other and to one of the speaker terminals?
Check and confirm for both sides.
If so, the TIP35s will have their center leg/pad connected to (~0 ohms) the positive terminal of the rail capacitors. The rest are TIP36s.
Bias adjustment for Punch150 transistor outputs brandes.cm Car Audio 2 7th July 2010 11:39 PM
Spring/Clips mount transistor where to buy ( RF, PPI, Boston and more ) lee1976 Car Audio 1 12th March 2010 10:07 AM
PPI ART Series a404 "v" PPI Powerclass pc450 swap chemhaz Car Audio 2 21st November 2008 02:23 PM
replacing 2SC3281/2SA1302 outputs, transistor matching nick78 Solid State 27 13th August 2007 10:30 PM
PCX1250 2ohm mode Problem ctg353535 Car Audio 1 15th April 2007 02:26 AM
Page generated in 0.07157 seconds (66.91% PHP - 33.09% MySQL) with 10 queries
