Go Back   Home > Forums > General Interest > Car Audio
Old 9th November 2011, 01:29 AM   #1
Default Massive P3000.1
I can not get one supply to power up. There is a header labeled J12, any ideas? J14 carries the remote from the first power supply. The output of the TL494 is garbage because I have no supply at the chip.
Interesting amp here, came to me with the rectifiers replaced with a TIP32 and two FQP50n06's. Not sure how they expected it to work!!
Old 9th November 2011, 01:36 AM   #2
There is a header for the LEDs in the heatsink on some versions.
Old 9th November 2011, 01:42 AM   #3
I think I found the issue, Q17 was shorted. Marking was M6, am going to use an A56 in place.
Old 9th November 2011, 02:07 AM   #4
That was part of the issue, the output of the TL494 is still garbage.
Old 9th November 2011, 02:41 AM   #5
Q17 and 18 are in parallel. If you replace one, you should replace both.
Old 9th November 2011, 02:42 AM   #6
Post a photo of the output.
Old 9th November 2011, 12:28 PM   #7
I replaced both, I can hear something click and see on the scope as if it wants to start up. Here is the output waveform. I do get a lower than normal -40V rail and nothing on the positive side.
Old 9th November 2011, 12:37 PM   #8
Do you have a clean sawtooth waveform on pin 5?
Old 10th November 2011, 12:50 AM   #9
The signal is there right away, but has noise riding with it. Then it disappears to essentially what the waveform I posted looks like.
Old 10th November 2011, 12:51 AM   #10
See if pin 7 is a clean ground (no noise or ripple).
Hafler P3000 trans nova volume potentiometer... ladaniva Solid State 4 27th May 2011 06:29 PM
Massive P3000.1 massive DC offset amc32 Car Audio 5 16th March 2011 05:40 PM
Massive p-1500.1 mike49504 Car Audio 27 7th April 2010 09:16 AM
Hafler P3000: crackling in right channel carpenter Pass Labs 1 7th October 2009 02:37 PM
Hafler Trans Nova P3000 Amp for sale susant99 Swap Meet 0 27th December 2006 06:02 PM
Page generated in 0.09407 seconds (75.79% PHP - 24.21% MySQL) with 11 queries
