This powers up fine, relay kicks in also I play a test tone thru it and it passes thru the preamp board fine but cannot seem to figure out why no sound, i have checked all the fets and regulators and they seem ok maybe I am checking them wrong, someone help me if you have some knowledge of any of these symptoms
#2 |
Is the center leg of all of the output transistors at ~0v when the amp is powered up (black probe on negative speaker terminal)?
Do you read approximately either positive or negative 70v on the 3rd leg of all of the output transistors? Be very careful not to short the probe to the clamps while measuring the voltage.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
3rd leg being on the right or left?
#4 |
See attached.
#5 |
thank you ill check
#6 |
.002 ~V on center leg
#7 |
55.3 Vdc on 3rd leg on each my power supply is kind of weak , it does right at 11.9 to 12 v
#8 |
Did you have negative 55 on some of the outputs?
#9 |
on one i did yes
#10 |
All of the IRF640s should have -55v on the 3rd leg. All of the IRF9640s should have +55v on the 3rd leg. Recheck.
| Need schematic for kicker zx750.1 | no1stunna | Car Audio | 19 | 11th January 2012 04:10 PM |
| Need help with no sound from kicker zx750.1 amp | kylelemay1 | Class D | 0 | 7th May 2011 04:46 PM |
| Help for a Kicker ZX750.1 that goes into protection in 15 mins & does not get warm. | BIG4REST | Car Audio | 0 | 14th August 2009 09:40 PM |
| Kicker zx750.1 | texasrebel1 | Car Audio | 2 | 10th January 2009 04:46 PM |
| Kicker zx750.1 solobaric 10's | texasrebel1 | Car Audio | 2 | 5th December 2008 01:27 AM |
| Page generated in 0.08080 seconds (84.27% PHP - 15.73% MySQL) with 11 queries |
