Go Back   Home > Forums > General Interest > Car Audio
Old 6th November 2011, 07:16 PM   #1
Default taramp 6500
This unit is powering on , and after a few seconds it goes into clip light on ,continues flashing every second, there is no 21khz out of pins 25 and 26 of the micro controller PIC, 50 kHz are present at pin 23 of PIC. Originally this amp came to me with all the power supply mosfet shorted out, at this moment no mosfet are in the power supply, can the PIC be on protection mode for the power supply section or is it just bad?
fluke 50 mhz scope,35 amp power supply,0.5-12v adj power supply, fluke 179,hot air desolder gun, merit multyfuntion signal tracer/generator.
Old 7th November 2011, 06:47 PM   #2
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
PIC could also be dead... what else apart from fets was or still is dead?
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 8th November 2011, 04:30 AM   #3
Becouse the 50 khz out of pin 23 are present, and the amp powers up ok
I was i was just wondering, if the problem was coming from a shutdown
condition, place else.
Old 8th November 2011, 05:26 AM   #4
luka's Avatar
but does shutdown come from any other place?
I don't know it this is possible, but is it possible that supply pins are ok, and pin that are for output are not?
And I wouldn't say amp powers up ok, ok sure power supply still works, but that led is saying it is in protect, isn't it? I would try to find, how does pic know when there is an error, there must be some circuit that detects all sorts of things and adjusts the voltage so pic car read it
See if that part of the is ok, coz program in pic seems to be still running
And try to find if you can get new controller for teramps, if you would need to replace it
I FEEL SLOVENIA
Old 24th November 2011, 10:43 AM   #5
fcruz is offline fcruz  Brazil
check the resistors that are going to pin 2 of the pic are two and a 22k 8k2 + b leaves they can be altered
MTX 6500 D mike49504 Car Audio 20 14th October 2011 05:25 AM
MTX Thunder 6500 D mike49504 Car Audio 4 21st July 2011 11:01 PM
Hitachi HCA-6500 vksamael Solid State 0 2nd August 2010 07:05 PM
sansui qrx 6500 sondadareas Solid State 0 19th September 2009 03:31 AM
Page generated in 0.08144 seconds (79.02% PHP - 20.98% MySQL) with 10 queries
