I own a gta 800m that recently died. It's out of warantee and I have experience as an audio tech, so I opened it up. I replaced the output and power transistors, along with the driver transistors for the TL494. I also replaced a 22uF cap near the output relay that appeared to be bulging. The amp is still in protection mode and I only get 6v at Vcc of the TL494. |
#2 |
Can you post a photo of the inside of the amp?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
I've also included a closeup of the TL494. The traces around the IRF3205's were really burnt up. The hot glue was me insulating the traces I had to fix, along with the 47 ohm resistors I had to replace.
#4 |
Does Q1 supply 12v to pin 12 of the 494 via the 10 ohm resistor?
If so, post the DC voltage on all 3 pins of Q1.
#5 |
No, the 10 ohm resistor feeds the IRF3205 drains. I did some tracing on the bottom of the board and pin 12 of the 494 comes up between Q14 and R17, and again between R30 and Q9.
#6 |
Are you referring to the 10 ohm resistor next to Q1?
Did you find that connection with your meter or did you follow a trace? Did you find any low resistance connection between any pin on Q1 and pin 12 of the 494?
#7 |
The center pin of Q1 has continuity with pin 12 of the 494.
#8 |
Please answer all of the questions.
#9 |
Sorry.
I am referring to the 10 ohm resistor next to Q1. I found that connection with my meter. There is a low resistance connection between the center pin of Q1 and pin 12 of the 494. |
#10 |
If you look at the drains of the power supply FETs (with a scope) after you get the amp working, you'll see that the resistor is not connected to the drains. The connection that you found between the resistor and the drain is through the transformer's primary winding.
Does the other end of the 10 ohm resistor connect to the firs leg of Q1? What do you mean by 'low resistance'?
| Boston Acoustics G21244 for home use | slovell | Subwoofers | 1 | 24th October 2011 01:51 PM |
| Boston Acoustics GT-40 | mike49504 | Car Audio | 20 | 7th October 2011 02:20 PM |
| Boston Acoustics S60 Components | slovell | Car Audio | 0 | 18th December 2010 01:24 PM |
| Boston Acoustics A150 | jamwvu | Swap Meet | 0 | 6th July 2007 02:09 PM |
| Boston Acoustics HD 10 | 70s music | Multi-Way | 3 | 13th June 2007 09:30 AM |
| Page generated in 0.09434 seconds (77.73% PHP - 22.27% MySQL) with 11 queries |
