The two mylar caps in the output filter circuit are completely toast, would anyone know the value? The only number I have for the pcb is 1325-52759-05. RF support is down and can't ask for a schematic, I would guess they won't release it anyway.
Gate resistor value for the PS fets as well? I have never seen such a mess before, apparently the guy didn't fuse this amp. The PS fets started on fire and actually cooked the paint on the clamp. |
#2 |
From photos I have, it appears that the output filter caps are 6.8uf. I can't read the voltage. The gate resistors for the power supply are 60.4 ohms.
At least it's repairable. The following amp wasn't. IrfanView HTML-Thumbnails
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Would you have a schematic for anything in that era?
brandes.cm@gmail.com The current sense resistors Dale WSR .01 ohm, 3W or 5W? They list the same package size for both. The 5W may have the pad on the bottom of the package though. |
#4 |
The ones in the amp photos are marked WSR-3 which are 3w resistors.
Sorry, no schematic. They weren't releasing it when I last inquired.
#5 |
The caps are 100V, was able read one once it was removed and cleaned.
#6 |
Still having issues with this amp. If I just apply B+ and gnd or Rem and gnd I have no issues. I can see the gate drive signal in the power supply. One side goes from gnd to B+ and the other is referenced above gnd and switches from here to B+. Looks to be a nice square wave at 50% duty cycle.
Should the sync signal be sawtooth 100Khz? I am basing this off the 1000BD schematic I have. |
#7 |
Cancel that, I see the sync signal is suppose to be a low pulse just as it's acting.
I pulled the rectifiers and still the same reaction of my supply going into over current mode. Maybe the transformer is garbage? |
#8 |
If the drive signal on the gates doesn't go all of the way to ground, the PNP drivers are likely defective.
I've never seen a sawtooth waveform on the sync pin but I rarely check that pin. The frequency will be twice the frequency of the output frequency on pins 13 and 16.
#9 |
I was getting the 100Khz carrier and sync signal mixed up. The sync looks to be generated from a set of Flip-Flops from the carrier signal. It's divided by 2 first then the sync is generated.
I will just pull that board again and replace the drivers. |
#10 |
All working now, thanks again.
Bad drivers causing my grief. |
| rockford fosgate t2000-1bd blown power supply mosfets | 2sheezy | Power Supplies | 3 | 4th October 2011 07:59 PM |
| rockford fosgate t2000-1bd blown power supply mosfets | 2sheezy | Car Audio | 15 | 4th October 2011 12:50 AM |
| Laser Pickup´s M52103FP RF-Amp instead of older CX20109 RF-Amp | Salar | Digital Source | 2 | 25th July 2010 05:44 PM |
| Tips on fixing my Rockford P1000-1bd | jamesnail | Solid State | 8 | 30th January 2010 09:56 PM |
| rockford p600.1bd amp | Cal Weldon | Car Audio | 0 | 7th September 2009 05:47 AM |
| Page generated in 0.16465 seconds (65.18% PHP - 34.82% MySQL) with 10 queries |
